Show
Suspention Tracking Issue
#1
Posted 18 July 2007 - 10:11 PM
#2
Posted 19 July 2007 - 12:11 AM
#3
Posted 19 July 2007 - 05:41 AM
#4
Posted 19 July 2007 - 05:47 AM
I have a '99 GS300 with 103,000 miles that I took in for service recently. I had the timing belt changed along with some other things, one of the things I had done was a 4-wheel alignment. I figured since I've never had it done it was time. After I got it out, I noticed something different about how the car rode.....I noticed when going down the highway the backend would seem to sway right to left when going over large dips. It is not a problem around town but once I get past 70 the car feels slightly unstable when going over a lot of dips. Has anyone else experienced this?
I saw where someone one with a previous generation GS (93 - 97) had the same problem but I never saw anyone respond with an answer. I'm hoping I'm a little luckier. I'm going by the dealer ship in a couple of days and I hope to offer some 'suggestions' to him because I have a feeling the 'Service Manager' is going to think I'm half crazy.
Thanks for any suggestions you guys can provide.
Well, I have good news and bad news for you. You were probably reading about my car. I was just logging on to write an update on this problem. And yes, this can be a really spooky condition.
I had this same thing happen to my '96 GS with 85K on it. The Toyota dealer was stumped. I took it to Lexus. They had no less than 5 technicians, including their chief diagnostic guy pour over it for about a week. What they finally came up with was this:
1) Bad wheels bearings on the passenger side, rear.
2) Bad bushings on the driver's side #1 control arm (vertical one)
3) Bushing on the rear cradle that isolate the the cradle from the body were deteriorating.
It took them another week to get the parts, then they had to remove practically the entire rear suspension to replace the bushings. The total for parts and labor was over $2K. They knocked 10% off the bill for me since it took them so long to figure it out.
I just got the car back at the end of last week. The problem was fixed. My car is in great shape other than this issue, so it was worth it to fix it. I plan to keep the car for a couple more years. If the rest of your car is not so great, then you have a judgement call to make.
I would recommend that you do fix it right away, as this tends to get worse and can ruin other parts. I would probably have them check the #1 control arm first to see if that corrects the poblem and then go from there. Maybe you'll get lucky and not have to replace as much as I did.
Good luck!
#5
Posted 19 July 2007 - 09:59 AM
I found this for you. I didn't want to re-type everything so i copied and pasted these from an old post I found. The first is a guy asking about a problem that sounds like yours. The second section is a response that seemed to help. Good luck.
Good luck!
Thanks Athenslex - I did see this post and hoped there might be something easier and cheaper. I'll keep this site updated as to what I find. Oh, I do know it is spelled suspension - up too late last nighg
