AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
Sign in to follow this
flyguy1996
92 Ls400 Blower Motor Resistor Diagram/location
flyguy1996    0
The low setting on my a/c would occasionally start blowing at medium speed then revert back to blowing at low speed from time to time, irregardless of whether it was on auto or manual. Meaning, even if I selected low speed, it would still blow at medium speed. Yesterday, it stopped reverting and now my fan runs no slower than medium speed all the time (unless switched off). My guess is it's the blower motor resistor, so I'd like to replace it. But I can't find any diagrams that show where it's located or how to replace it (I've checked the forums here, but couldn't glean enough to help).
Does anyone have experience replacing the blower motor resistor on a 90-92 LS400, and if so, can you explain the procedure? Would appreciate a diagram, too, if someone is kind enough to post one here.
Thanks in advance!
Tony
Share this post
Link to post
jeffls400    0
The blower motor resistor is mounted inside the evaporator / blower motor housing. I think you would have to remove the entire assembly to switch out. It resides behind the glovebox and its removal would require evacuating the a/c system.
Share this post
Link to post
wwest    1
Thanks in advance!
Tony
If I remember correctly the 92 has a power transistor that controls blower speed up to MAX wherein a relay kicks in to eliminate even the slight voltage drop of the transistor in saturation. I don't remember where exactly the power transistor is mounted but I would suspect the driver circuitry in this case rather than the transistor itself.
Share this post
Link to post
flyguy1996    0
Oh boy. This doesn't sound like fun :unsure: Maybe it's best to bring it in and have them fix it. Just didn't want to spend $500 in labor if it's a $30 part and work I can do myself.
Share this post
Link to post
bright    0
Thanks in advance!
Tony
Dear Tony,
I have the same problem in my 1995 SC400 now. I was wondering if you are willing to share the solution to your problem.
Thanks,
Bright
Share this post
Link to post
