sisterpete Posted July 6, 2007 Share Posted July 6, 2007 anyone ever removed the ECM on a 1991 LS400? I am needing to do this as all else has failed trying to find out what my problem is.... any help would be great. My understanding is that it's behind the glove box. thanks Quote Link to comment Share on other sites More sharing options...
illCelsior Posted July 7, 2007 Share Posted July 7, 2007 Remove the bottom most panel beneath the glove box by removing the three bolts (I think it was 12mm). With the bolts removed - pull back the lower panel carefully. Do not break any clips. :) Pull back the part RIGHT BELOW the glove box. This is NOT the same panel as the one above. The ECM is attached to it. Have a peek up at your ECM/ECU. You can remove it by taking off the 3 bolts holding it to the panel. HTH Quote Link to comment Share on other sites More sharing options...
sisterpete Posted July 7, 2007 Author Share Posted July 7, 2007 Remove the bottom most panel beneath the glove box by removing the three bolts (I think it was 12mm). With the bolts removed - pull back the lower panel carefully. Do not break any clips. :)Pull back the part RIGHT BELOW the glove box. This is NOT the same panel as the one above. The ECM is attached to it. Have a peek up at your ECM/ECU. You can remove it by taking off the 3 bolts holding it to the panel. HTH very cool... thanks for the info. one other question... is it marked as "ECM"? Quote Link to comment Share on other sites More sharing options...
