Show
New 2014 IS -F-Sport
Check out the latest official 2014 Lexus IS F-Sport pictures
How Often Do You Check Engine Oil And/or Tire Pressure?
  • Please log in to reply
10 replies to this topic
#1 coolwater
coolwater
    Advanced Club Member
  • Regular Member
  • PipPipPip
  • 117 posts
  • Model: 2000 ES300 Platinum (Gone)
Posted 28 November 2006 - 09:11 AM
Okay, I confess that I haven't pulled out the engine oil dip-stick nor checked tire pressure myself for more than a year now. :unsure:
How often do you check engine oil and/or tire pressure?
#2 dcfish
dcfish
    Guru Member
  • Gold Member
  • 10,992 posts
  • Model: 98 GS300, BLK/BLK
Posted 28 November 2006 - 10:21 AM
Everytime I fill my car with gas all fluids are checked along with the tire pressure. Just a good habit to get into. ;)
#3 lexusk8
lexusk8
    Dedicated Member
  • Regular Member
  • PipPipPipPip
  • 502 posts
  • Model: 2001 ES300
Posted 28 November 2006 - 11:37 AM
I check oil every time I fill up at the gas station, and I check my tire pressure once a month.
#4 Tsquared
Tsquared
    Club Member
  • Regular Member
  • PipPip
  • 48 posts
  • Model: ES 330
Posted 28 November 2006 - 06:48 PM
Check the oil at the first fill after it rolls over 1000 miles. At 30K it does not burn any oil.
I check the air evry time I rotate the tires - every 5k miles when I perform the PM on the oil/filters/other fluids.
#5 abrarcool
abrarcool
    Club Member
  • Regular Member
  • PipPip
  • 63 posts
  • Model: 1999 ES 300
Posted 28 November 2006 - 10:16 PM
on the weekends when i dont have to rush anywhere before leaving home
#6 SW03ES
SW03ES
    Official LOC Detailaholic
  • Management
  • 18,532 posts
  • Model: GS350 AWD Lux
  • Year: 2013
Contributor
Posted 28 November 2006 - 11:19 PM
I get gas twice a week so if I checked the oil and the pressure each time it'd be overkill. I do check them every other wash though (every other week).
#7 camlex
camlex
    Guru Member
  • Regular Member
  • PipPipPipPipPip
  • 1,072 posts
  • Model: 2000 Lexus ES300
Posted 29 November 2006 - 09:07 AM
You are driving LEXUS.
Between oil change, I never do check oil level.
Tire pressure, why not @ discount tire.
Thanks,
#8 SW03ES
SW03ES
  • Management
  • 18,532 posts
  • Year: 2013
Contributor
Posted 29 November 2006 - 11:37 AM
Thanks,
Why does driving a Lexus mean you shouldn't check the oil level and tire pressure?
Lexus doesn't make tires, and checking the oil level is simply something a car owner should do to inspect it for wear and level.
#9 lexusk8
lexusk8
    Dedicated Member
  • Regular Member
  • PipPipPipPip
  • 502 posts
  • Model: 2001 ES300
Posted 29 November 2006 - 01:14 PM
^^ Exactly Steve. It's routine maintenance every car owner should do (i.e. check oil and tire pressure). Oil check takes no more than a minute to do, and to check the tire pressure, get yourself either a manual read-out gauge or one of those digital gauges (which I have that's also a key chain). You can find these gauges anywhere you go, even in a supermarket.
#10 Toysrme
Toysrme
    Guru Member
  • Regular Member
  • PipPipPipPipPip
  • 2,128 posts
  • Model: 1993 ES 300
Posted 29 November 2006 - 10:04 PM
Weekly, but I have a compressor @ the house, and a really nice intigrated tire pressure dial gauge / filler so. No big deal for me.
AFA the oil. I tend to check it every week, or so after I park & have a second. Just put an old clean rag in the corner of the engine bay. Swear to god you'll check your fluid levels 9,376 times more often if you know you won't get your hands dirty in the process!
And anytime you do the oil. Leave the engine idling & check the transmission fluid first!
I'm bigger on transmission checking than oil. For no other reason than at somepoint every village idiot will change the oil. Most won't touch the transmission fluid LoL!
#11 es300ed
es300ed
    Club Member
  • Regular Member
  • PipPip
  • 47 posts
  • Model: es300
Posted 30 November 2006 - 07:03 AM
I admit that I don't check oil and tire pressure on a regular basis. That said, My 96 with 105,000 miles has never lost a drop of oil or a pound of tire pressure. I have the oil changed every 4,000 miles or so. I may be wrong but I attribute the tire pressure to the metal valve stems which are screwed on the tire rims.
Ed
