How To Replace Taillight Bulb
LUKE a MANIA
first open the trunk and remove the liner that covers the rear of the trunk (it comes off by removing the plastic screw off hold downs).
Then, you will see 4 nuts at the rear of the tail light inside the trunk. Unbolt these (Can't remember, but I think they were either 8 or 10mm). You can then remove the taillight assembly.
You remove the bulbs by twisting counterclockwise (if I remember correctly) and pull the socket out. Should be obvious after this point. I would probably replace all the lights if it were me so I didn't have to do this for a while again. (2 stop lights, 1 reverse light, 1 blinker, 3 parking lamps)
  • 1 year later...
