Show
New 2014 IS -F-Sport
Check out the latest official 2014 Lexus IS F-Sport pictures
Step By Step Instructions For Iacv(idle Air Control Valve)/isc/throttl
  • Please log in to reply
231 replies to this topic
#1 GoldenStateSilverSport
    Advanced Club Member
  • Regular Member
  • PipPipPip
  • 129 posts
  • Model: 2001 RX300 Silversport / 2007 GS350
Contributor
Posted 08 July 2006 - 08:34 PM
Hello Everyone,
I know IACV has been a huge topic on the forum and I have found various pictures in the RX forum and ES forum on the idle air control valve (IACV) or as others call it the idle speed control valve (ISC). However, I have not found a "step by step" posting to date which definitively shows how to clean this thing so that my car stops giving me idling problems.
Symptoms I have had included:
- low and rough idling that would cause the car engine to start shaking after starting the car
- this eventually got worse to the point that when I start my car, it would not idle unless I gave it gas
- idling problems for me tended to occur more often after my engine was warm or had been sitting in the sun
I hope these series of postings help you fellow LOC members out there. You've certainly helped me in the past so here's my two cents at this common problem. Additionally, the instructions I give are the way in which I have cleaned it myself. As you go about and attempt this, you may find better ways to do so. Please add and refine my instructions/terminology as needed. I am not a professional. I've only changed my oil, air filters, and conducted minor maintenance previously. The bottom line is that if you have the right tools, you should be able to do this. This discovery/ cleaning took me about 2 hours to do cause I ran into problems and there were major steps left out in previous postings that I’ve encountered read. The next time I do this, I believe I can get this done in about an hour or less.
Tools Needed:
1) Tightly fitting Philips Screw Driver
2) Carb cleaner that is O2 sensor safe (I've seen CRC. I used Valvoline Carb Cleaner)
3) Locking Grip Pliers (definitely helped me remove the factory tight screws)
4) Small brush for cleaning
5) Towels for cleaning
6) Pliers (help removed brackets holding the hoses)
7) Latex gloves helps with limit the messiness.
* I used the same gasket and did not replace it. No problems found.
1) Remove the hose that comes from the engine/motor that connects to the air intake hoses.( Hose is below in red – we’ll refer to this as Hose A) When you pull back the rubber hose covering, you will see that a metal bracket is holding the hose pretty tightly in place. Use the pliers to clasps the two metal pieces together to loosen the bracket and pull the hose loose. You can also do this by hand if it’s easier for you.
Attached File  original_2.JPG   112.7K   15016 downloads
2) Upon removing the hose, you will want to remove the two air intake hoses. Loosen the three screws above in green and remove the hose. Below is a picture of the intake hoses removed.
Attached File  intake_hoses_only.JPG   165.78K   12067 downloads
3)After removing the intake hoses, I opened the lid to the air filter and moved this to the side of the car to create more working room. I believe there are two clips on the right holding the lid in place. Just pop the two clips and move the cover to the side. I also took out the air filter and temporarily moved this to the side.
Attached File  intake_hoses_removed.JPG   163K   13141 downloads
4)After removing the intake hose, the throttle body/IACV/black electric coil is revealed. At this point, I removed the black electric wire from the black coil. Once the electric wire is removed you can remove the black coil from the IACV by removing the two screws. Note, the screws are factory tight so use a tight fitting screw driver to remove the screws. One of my screws was partially stripped from the dealership’s work, so I had to resort to my locking grip pliers which helped out tremendously. After removing the two screws, the black electric piece pops right off. When the black electrical coil is removed from the IACV, it exposes a small pencil sized metal stud. You will also notice a washer that sits on this stud. Don’t lose this washer. Take it and put it aside so it doesn’t fall off when you continue on in the next steps.
Attached File  throttle_body_revealed2.JPG   149.09K   16075 downloads
5)Additionally, I removed the hose coming out of the IACV. We’ll call this Hose B. This hose can be removed in the same manner by clamping the bracket and pulling the hose out. You will see that the hose is removed below. Below are pictures of before and after.
Attached File  sensor_removed2.JPG   132.23K   16313 downloads
6)Here is where the fun begins. I initially attempted to remove the four screws attached to the IACV at this point, but found that after an hour, this would be nearly impossible to remove considering the location of the screws were in an extremely tight spot. The only way I would be able to remove the IACV is to remove right throttle body. Not as tough as it sounds. Three screws need to be removed to accomplish this. Again, be careful when removing the screws. Also you will see I removed another electric plug and I also cut a tie wrap. Once you complete these steps, the throttle body/ IACV comes out pretty easily. Note when you remove the throttle body, there will be one LAST hose connected to the IACV. Be careful when you remove this hose as radiator fluid may spill. Some of my fluid spilled out so I just refilled my coolant after I was done.
Attached File  throttle_body_connected2.JPG   109.13K   15130 downloads
7)Below is a picture of the bottom view of the IACV. You now can EASILY remove the four screws connecting the IACV to the throttle body . In the picture below, I have already removed one of the screws.
Attached File  bottom_view_iacv.JPG   174.08K   14027 downloads
Once the four screws are removed the IACV and throttle body separate. Now you can clean both of them with your carb cleaner, brush, towels, cotton swabs etc…. Picture here is before I the cleaning with all the muck inside
Attached File  iacv_removed.JPG   157.28K   12582 downloads
Pictures after I cleaned the IACV and throttle body
This last picture is the post throttle body cleaning
Attached File  post_throttle_body_cleaning.JPG   174.07K   11345 downloads
Attached File  iacv_upclose.JPG   157.38K   9491 downloads
Attached File  iacv_post_cleaning.JPG   135.87K   7670 downloads
8) Once you are done cleaning, just put back the throttle body/iacv the same way you took it off, and put everything back in reverse order. Ensure the gasket is in place. Also, ensure you put the washer back on the electric coil. Make sure you place hose A & B back and ensure the electric plugs are back in their original position. Once these things are in place, then it's all about putting the air filter/hoses back and you are good to go. If you have lost any coolant, make sure you refill it to a safe level.
After completing this cleaning, my car starts up without any problem and idles as if I just purchased the car brand new. Replacing this at a dealership would have costed me $300-400 easily. Let me know if you have any questions. Cheers (Also, I tried to post these as separate replys, but the software combined all my replies into a single reply and did not keep them separated)
*Edited the posting to have the pictures follow step by step in sequential order*
#2 GoldenStateSilverSport
  • Regular Member
  • PipPipPip
  • 129 posts
Contributor
Posted 10 July 2006 - 01:18 AM
By the way, I've been driving my car for 2+ days now after performing this cleaning and I can happily say I have not received any idling problems anymore. The car starts and idles perfectly now. Cheers!
#3 SKperformance
SKperformance
    Official LOC Bad Speller
  • Management Team
  • 12,489 posts
  • First Name:S
  • Model: 94-ES300 98-LS400 03-GS430
  • Year: 2008
Posted 10 July 2006 - 02:00 AM
Very nice.
#4 TunedRX300
TunedRX300
  • Regular Member
  • PipPipPip
  • 434 posts
  • Model: 2000 RX300 AWD
Posted 11 July 2006 - 05:05 PM
Good intructions, do you have to take off the black metal piece mounted on top on the two throttle inlet holes? What if you strip one of the three phillip screws on the throttle body? I believe they are excessively torqued at the factory...
#5 2bears
2bears
    New Club Member
  • Regular Member
  • Pip
  • 16 posts
  • Model: 2000 RX300
Posted 12 July 2006 - 03:20 PM
Very detailed information!! Thanks
Fred
#6 GoldenStateSilverSport
  • Regular Member
  • PipPipPip
  • 129 posts
Contributor
Posted 13 July 2006 - 11:12 AM
You don't have to take off the black metal piece. Once you remove the three screws holding the throttle body in place (I circled these screws as red in my picture), you just need to grab the throttle body and pull it down and out and it comes out easily. I removed the screws with an electric drill so it was much easier. I actually stripped one of the screws holding the electric coil in place so that is where the locking grip pliers really saved me, otherwise I would have been "screwed"..no pun intended.
#7 rx300scott
rx300scott
    New Club Member
  • Regular Member
  • Pip
  • 8 posts
  • Model: RX300
Posted 18 July 2006 - 02:03 PM
Great posting. Thanks for going to the trouble.
A question about the part....is it a dealer only part, or can it be bought aftermarket?
Thanks!
#8 GoldenStateSilverSport
  • Regular Member
  • PipPipPip
  • 129 posts
Contributor
Posted 18 July 2006 - 07:21 PM
Thanks!
What part are you referring to?
#9 Checho
Checho
    New Club Member
  • Members
  • Pip
  • 1 posts
  • Model: RX300
Posted 21 July 2006 - 10:37 PM
GREAT POSTING!!!! YOU JUST HELPED ME SAVE $620! SHOP WAS GOING TO CHARGE ME $650 (WHICH I CERTAINLY DID NOT HAVE LAYING AROUND) AND I ONLY HAD TO SPEND ABOUT $30 ON TOOLS. THIS POSTING WAS A GODSEND... THANK YOU AGAIN!
#10 GoldenStateSilverSport
  • Regular Member
  • PipPipPip
  • 129 posts
Contributor
Posted 30 July 2006 - 09:39 PM
Anytime! This forum has definitely been very helpful to me so I'm just trying to do my part in return for the members who can use my help. Plus I don't believe in unnecessarily spending hundreds of dollars ($650 in your case) to replace items and parts that don't need to be replaced but simply cleaned. Cheers! :cheers:
#11 RX?
RX?
    New Club Member
  • Members
  • Pip
  • 1 posts
  • Model: RX300
Posted 09 August 2006 - 02:33 PM
Did this cleaning for a friend , car did not run at all , at idle.
OK , managed to do it ,but a few questions :
- The small washer around the pencil size metal stud.Is it wavy? This one was , or is now...
- The idle RPM , what it should be ? At P & D positions.Engine warm. As the owner tried to raise the RPMs by tightening the throttle cable. It did help , but now it was idling way too high.And where is the idle screw ? If there is one...
- How much cleaning is required ? I cleaned allmost everything I could. The rotating piece (?) that comes off , and has these moving flaps , etc etc how much can you clean ? How much MUST you clean ? I managed to use the carbspray as a solvent , so most off the sh.. did come out.Some still remains. Should I worry ?What is the purpose of this "valve" thing? Does it suffer , from this "solvent cleaning abuse" ? It was stuck , when I opened it.Now it moves really freely.
A warning , the screws ARE TIGHT !!! Do not attempt with the wrong size screwdrivers !!!
The instructions are clear , and even I managed to do it ! And the result was impressive.... atleast I am happy myself !!!
#12 RX_4_surfin
RX_4_surfin
    Club Member
  • Regular Member
  • PipPip
  • 36 posts
  • Model: '01 RX300
Posted 09 August 2006 - 03:50 PM
Great directions Golden State. Much better than a manual. My '01 has been starting to idle a little rough in the hot weather lately and sometimes is a bit tough to start--sounds like this could be the culprit. I'll take some time and do this this weekend.
By the way, have you considered changing your timing belt and water pump? I could use some good directions on that, too. :)
#13 GoldenStateSilverSport
  • Regular Member
  • PipPipPip
  • 129 posts
Contributor
Posted 12 August 2006 - 01:07 AM
Good luck!. Nope, haven't changed my timing belt/water pump yet. I have a little over 70k miles on my ride so things are still looking good.
#14 WESSIDE RX300
WESSIDE RX300
    New Club Member
  • Regular Member
  • Pip
  • 3 posts
  • Model: RX300 LTD
Posted 04 September 2006 - 09:53 PM
:blink: hey thanks for this post!! i just performed this on my 2001 rx300 (98k miles) and it now runs like a champ!! had the symptons of stalling after start now its totally gone. took me about 2 hours. thanks again!!
#15 GoldenStateSilverSport
  • Regular Member
  • PipPipPip
  • 129 posts
Contributor
Posted 06 September 2006 - 01:21 AM
No problem. glad i could help!
