Is350/250 Owners Manual
  • 2 months later...
Hi Bartkat.
Do you have any manuals on the Bluetooth phone system. Around the voice dialling?
The only info I have is in the list above under "Nav other functions".
http://us.lexusownersclub.com/forums/index...ost&id=3776
I HAV THIS WEBSITE WHERE I FOUND THE WHOLE MANUAL FOR THE IS 350/250 AND ITS GOT EVERYTHING ONIT EXCET THE MARK LEVINSON SOUND SYSTEM WHICH MA I SAY IS NOT IN THE ORGINAL MANUAL SO IT IS THE COMPLETE MANUAL THE LINKS BELOW.
http://safemanuals.com/user-guide-instruct...S%20-%202006-_E
  • 3 weeks later...
Bartkat: I cant get to the part in the manual that tells more about warning lights, I click on the link and an error message comes up! But neway the problem is I need to reset the warning light that says "oil maint reqd" the mechanic says he needs the manual to get the instructions on resetting it, howevere I have lost my manual. Any help would be great!! Thanks
After changing the engine oil (U.S.A. only)
The oil change system should be reset. Perform the following procedures:
Switch the display to the odometer (→P. 105) when the engine is running.
Turn the engine switch OFF.
While pressing the trip meter reset button, set the engine switch to the
IG-ON mode (but do not start the engine because otherwise the reset
mode will be cancelled).
Continue to press and hold the button until the
trip meter displays 000000.
downloadOwnersManual.do.pdf
  • 6 months later...
  • 2 months later...
  • 3 weeks later...
  • 3 weeks later...
I don't think you posted Section IV of the Nav System manual. Do you have that available? Thanks again! :P
pret auto
I never found it but it may be in the manual you can get here:
Or go to Lexus.com and under the owners section register your VIN and you can access the maunal there.
  • 10 months later...
  • 8 months later...
  • 7 months later...
Hi
is there anywhere the complete repair and service manual of IS250 2008?
I even bought one on line but it does not give the information i need which is the wiring of the engine and car control unit.
Many thx for the help
Kazama
  • 7 months later...
  • 1 month later...
