97 Es300 Fuse Panel...
Seanhsueh
Does anyone know where the Fuse Panel is on a 97 ES300?  How many are there?  Thanks
you know that lil pocket to your left? yes that on beside the wheel below the truck realse and gas door button. open it and firmly pull up it will pop out. behind it is a fuse panel. it might be hard to pul but u cant brake it. on and under the hood too. i will let u look for that one. :D
Thanks a lot guys. I appreciate your help. I'm trying to find the fuse panel so I can power up a CD Changer I installed recently. I need to connect it to a 12V power source and I decided to go with fuse taps so I can avoid splicing. What do you guys think? Is this the best route to go?
