Show
New 2014 IS -F-Sport
Check out the latest official 2014 Lexus IS F-Sport pictures
How To: Change Headlight & Parking Light Bulbs
  • Please log in to reply
26 replies to this topic
#16 Spyderdaddy
Spyderdaddy
    New Club Member
  • Members
  • Pip
  • 1 posts
  • Model: 1994 LS400
Posted 03 September 2007 - 04:23 PM
Lex 92, Great! instructions, loved the fact you included pictures. I just changed out my
1994 Lexus LS400 bulbs (H-4) with some super bright Hi-Lite Xenon replacements.
Man I really had to pull on those corner lights to get them to pop loose, was worried I would
bust them, but they finally came free. Thanks again for posting instructions.
Respectfully, Spyderdaddy
#17 Buckaroo
Buckaroo
    New Club Member
  • Regular Member
  • Pip
  • 7 posts
  • Model: 1990 LS 400
Posted 12 July 2008 - 12:06 AM
Thanks for making the effort to tell us how to replace a headlamp! Couldn't quite figure out how to do it so your post was right on! The only thing you could do better would be to come to my home and do it for me. Well, that might be asking too much. Seriously, thank you very much!
#18 beastieb
beastieb
    New Club Member
  • Members
  • Pip
  • 1 posts
  • Model: 1993 SC 400
Posted 11 January 2009 - 08:24 PM
It took me less than 20 minutes total to remove, clean up and put both sides back together.
You'll need:
Phillips screw driver
10mm socket
Remove this (1) phillips head screw to remove corner:
Posted Image
Hey lex great post any chance you still have the photos for this ? I need to do this to my car tomorrow.
Thanks!
#19 JTom
JTom
    Club Member
  • Regular Member
  • PipPip
  • 21 posts
  • Model: ES400
Posted 31 October 2009 - 04:57 PM
Looks like it's gone. Would love as well.
#20 Vinodh
Vinodh
    New Club Member
  • Regular Member
  • Pip
  • 11 posts
  • Model: 1999 es300
Posted 13 November 2009 - 08:05 AM
Hey Lex92,
Can you please share the photos if you still have them? Thanks.
Vinodh
#21 fuzzilogyc
fuzzilogyc
    New Club Member
  • Members
  • Pip
  • 1 posts
  • Model: GS300
Posted 26 April 2010 - 02:30 AM
If you have any questions, please don't hesitate to email me.
I'm looking to change my park lights from amber to white ones to match my HID's. Would also love to have these pictures. Any chance of posting them back up? Cheers
#22 CBSSYS
CBSSYS
    New Club Member
  • Regular Member
  • Pip
  • 6 posts
  • Model: LS430
Posted 07 June 2010 - 03:36 PM
I got the bulb out but I really need the pix in order to do this job. Where did they go? Can I find a diagram anywhere else? Have a 2004 LS430. Need to replace the HID bulbs. Please help!!!
#23 cduluk
cduluk
    Guru Member
  • Regular Member
  • PipPipPipPipPip
  • 2,414 posts
  • Model: 2008 Rx400h AWD
Contributor
Posted 07 June 2010 - 04:10 PM
You've already got the HID bulb out? What do you need more help doing?
#24 lexuslady2010
lexuslady2010
    New Club Member
  • Members
  • Pip
  • 1 posts
  • Model: 1998 Lexus GS400
Posted 26 September 2010 - 05:19 PM
Are these directions the same for a 1993 Lexus LS400?
#25 1990LS400
1990LS400
    Guru Member
  • Regular Member
  • PipPipPipPipPip
  • 4,536 posts
  • Model: LS400
  • Year: 2000
Posted 26 September 2010 - 06:14 PM
Yes, it is all the same except that the 90-92 LS400 uses an HB1/9004 headlight bulb and the 93-94 LS400 uses an H4/HB2/9003 bulb.
#26 wagindahow
wagindahow
    New Club Member
  • Members
  • Pip
  • 1 posts
  • Model: ls 400 1990
Posted 09 December 2010 - 01:11 AM
1990 ls 400--- tail light indiator on the dash is on and I am now blowing 20 amp fuses every 4-5 days
HELP
B
Email me
#27 Gary Krohn
Gary Krohn
    New Club Member
  • Members
  • Pip
  • 1 posts
  • First Name:Gary
  • Model: 1992 LS400
  • Year: 1992
Posted 18 February 2012 - 12:55 PM
Here's a shortcut I use to replace the lightbulb, at least on my 1992 LS400. Basically, instead of removing the entire assembly, you access the bulb while the assembly is still in place.
Step 1: After pulling away the sidelight assembly, look inside. You will see the gray electrical connection and black ring that locks the light bulb.
Step 2: Looking down on the top of headlight assembly frame, you will see a rubber gromet, about 1" in diameter. Remove it. Will a light, you should see the top of the gray electrical connection.
Step 3: Remove the gray electrical connection. You can do this either through the opening where the sidelight was pulled out, or from the 'access' hold described above. I prefer to use a long flat head screw driver from the side.
Step 4: Reach in through the opening and untwist the black ring, and remove the bulb. (Tight fit, but it will come out. The left hand works best for the passenger side, and your right hand works best on the driver's side.)
Step 5: Put black ring around new bulb and insert back into hole. (I use latex gloves to avoid getting body oil on the bulb.)
Step 6: Put gray electrial connection on.
Step 7: Test. (If something has gone wrong, better to know now rather than after everything is reassembled.)
Step 8: Reinstall sidelight assemby.
