I then started looking at turbo kits for my car and realized that all of them were several thousand dollars with performance comparable to a stock 2JZ GTE. I decided then to go all out and do a complete swap. Since the VVT-i 2JZ-GTE is limited both in the terms of availability and possible power output, I purchased a non VVT-i 2JZ GTE from a 95 supra complete with ECU and tranny. I contacted a local shop and they said they would be able to do pull it off. Sure enough, they installed the motor and they were able to make it fit perfect in the car. The only problem is that they were never able to get it started. Apparently, the pre VVT-i 2JZ GTE sends analog signals while the the 2nd generation GS300 deals only with digital (so I was told by the guys at SP Engineering). The only way to get this thing to work would have been to either rewire the car completely or use a stand alone management and even then, I would lose most of the creature comfort in the lexus. Needless to say I am happy that ebay was able to quickly help me find a good home for that motor
Thought I'd give up? Heck no! I was determined now to have a twin turbo GS300 and I knew it was possible since SP Engineering has one featured on its web site. I decided to follow the path they had followed and started looking for a twin turbo VVT-i 2JZ GTE. After much searching, I found one complete with ECU and transmission. It was expensive, but I figured that my wife and kid could go a couple of days without eating; they would understand it's for a good cause :-D Of course I had to pay almost another grand for the shipping but finally the motor arrived. I decided then to get the car towed to local performance shop I had heard a lot of good about.
Since the motor came out of a 2002 Aristo, it was not able to fit right in since the mounts of the Aristo are apparently different from that of the GS. I ordered the Aristo mounts from Japan and anxiously awaited their arrival. Once I got the mounts, the engine and tranny were able to go in smoothly and almost all the wires plugged in without a hitch. They had to modify the shift linkage of the tranny so that it would work with the lexus but after that everything was fine. When it came time to get the car started, it would crank but would not start. There was no pulse to the injectors. One of the guys there managed to figure out what the problem was and finally the motor came to life. What a beautiful sound
Once the car is started, it is impossible to move the shift lever from PARK but if you turn the ignition off, the shift lever moves without any problems. Another thing is that the key won't come out of the ignition if the battery is connected. Apparently that has to do with the E7 connector which seems to manage a lot of the security duties on the lexus. Unfortunately, the Aristo ECU does not come with a plug for that connector and right now we are basically stuck until someone over at that shop or a savvy reader from this forum can figure out what the problem is. Also, the RPM is not working either but still, I am very happy:D
With the ignition switch off, I put the car on neutral then started it. From there, I was able to switch to drive. With the boost set on high, thanks to my EVC Pro, the car was able to make child play of the traction control and literally liquefied the rear tires. I never knew a GS could move so fast
