before i repaired my p/s pump i did quite a bit of research on this forum and a couple of others to gather pertinent info to prepare for the task. i noted a recurring
comment in a lot of the posts regarding leakage problems to the tune of: "well i
got my pump repaired and now i have to worry about a leak on my rack". a post just today played the same song.
is it possible that when the solenoid filter on the rack gets excessively plugged,
it creates so much system back pressure that the seals give in both the pump
and rack and that is why the problems seem to be concurrent. actually, this could
relate to hose failures also. i'm not implying all failures are due the the filter but
maybe a significant percentage.
if so, it would be prudent to check/clean the filter on a periodic basis as a preventive measure.
any thoughts any1??
lx
