Thanks. Well, its going to be about $50-$60 for a used working solenoid, so I guess I will go ahead and try that and go from there. Mine has only did that "had steering one minute OK, then hard the next a couple of times... when it went out, it seemed to do it suddenly and now its only a rare case when its easy to turn.
It was like flipping a switch as well, but it only happened a couple of times and that was the end of it. It started as a shudder on low speed turns.
No, cleaning the PS pump screen is about the only thing I have not done. I was told you could jab a screw driver down in there and poke it out, but not sure if I want to do that, although I have been angry enough to do it.
If I can figure out how to do it without taking the pump off, I will try it.
We have a local Lexus dealer, but I would not trust them with my lawnmower, since they did not change my oil last time I took it there after paying them $63 to do so. I have since been taking it to the local Toyota dealer and they charge about $50, but since I now have my under engine cover off, I see how easy it is, so I will probably start doing it myself and save about $30.
I have a friend whose dad is a Toyota mechanic and he has done SOME work for me in the past, but last message I left him, I asked if he would clean the solenoid and PS pump screen and he never even returned my call. I am not begging anyone, so me and my dad took the solenoid off and cleaned it ourselves, which is when we cleaned the screen, then discovered that the solenoid was not clicking.
Its hard to find good mechanics that know about Lexus cars. Even one I know that supposed to be one of the best said he didnt even know of a screen on the steering rack and then I mentioned my car needed valve cover gaskets and he said the "back" one was hard to change. He thinks my LS400 has a V6. I have even let him see the car before and he still thought it was a V6 next time I mentioned some work I needed done. He has it confused with an Avalon and ES300. Oh well.
Thanks for the info however!
QUOTE (914lps @ Nov 22 2009, 03:22 PM)
You asked my to respond so I will. If your solenoid is bad, replace it. It could be the issue, or part of it. When mine as clogged, but working, it was like someone was flipping a on off switch to my power steering. Get and easy one moment, totally gone the next. At all speeds, but mostly when corning.
I cleaned the solenoid screen, then cleaned the screen in the pump, then put a inside the hose filter in the return hose. All screens have stayed clean. After I cleaned them, I flushed the system, with lots of fluid.
I see you have done a lot, but have not cleaned the screen in the pump. Please do it. I cleaned mine on the car. I put some B-12 chem tool into the reservoir, drove the car a little, then I used a turkey baster (use a metal one) with a short hose on it, to suck the fluid out of the reservoir.
I then filled the reservoir with B-12, and let it sit over night. I then rigged a shop vac to a small hose, and sucked the fluid out, and let the hose rib on the screen. I did this several times, vacuuming the screen. I then flushed the system, added the filter, and all was fine after that. I may have posted about doing this.
If you can take the reservoir off the clean the screen that is the best way to do it. Also on using a shop vac. This can dangerous, as an older one cal ignite the vapors. Myth Busters did a show on that.
If you do not have a local Lexus mechanic you know and trust, not the dealer, post on this board asking for a recommendation for your area.
And have it checked out by a mechanic.
I understand wanting to kill the F-N car..... I just had a PS leak at the Idle up valve kill my alternator!
I hope this helps. One last thing, based on what I have seen on this board. Monarch is a go to guy. Try asking him.
