QUOTE (chesnutlane @ Nov 5 2009, 09:44 PM)
Hi I am a master tech with certification from Hunter Alignment too and I hope I can give you a few pointers or at least some questions to ask your shop but more info is needed. When you say feathering is it all across the tire or does it have a heel and toe effect ? down certain parts or the entire tire ? 99% of the time its the struts as their primary purpose is to take out wheel osicalation.
Also are the factory size wheels installed ? The reason I ask is that will open up another ball of wax with rearspacing aka backspacing and posotive and negative offsets You naturally never want a "0" alignment because as you drive down the road the tires will push themselves outward if anything 1/16" toe in is ideal.
Feathed edges:
1. caused by incorrect toe setting
2. Feathered edges can be felt more than seen
3. sometimes can look like a camber wear
4. excessive toe in = feather point in
5. excessive toe out = feathers point out
6. feathered edges can also be caused by loose steering linkage
General tire wear charastics :
underinflation- will cause inner and outer edges of the tire to wear
overinflation- wears out the center rib of the tire
camber wear- (outside edge wear) can also cause a steering pull
excessive posotive camber = outside edge wear only
excessive negative camber = inside wear only
I can go on and on but feel free to say hello take care tim
QUOTE (Airtraffic @ Nov 7 2009, 08:01 AM)
Hi Tim,
Thanks for the response.. Yes, the feathering is more felt than seen. It is primarily along the outboard edge of the tire. about 1/2 inch or so in from the sidewall. They are the stock size factory rims with no modifications whatsoever to the suspension, no spacers etc.. Fronts are worse than rears.
The tires are the new Continental Contact Extreme DWS tires.. I wonder if part of the problem is that the continentals are still very noisy as previous versions of the tire have been.
I wouldn't think tire pressures would be an issue as the tires were installed a little more than a week ago, but you never know, I'll check again today.
When was the last time you, or the previous owner replaced the suspension components? I'm a little surprised by master technician chestnutlane as the fact that your car is now 15 years old and probably way past due for a complete suspension overhaul was completely overlooked. Your at a time when it's probably not going to be any one component that is causing your trouble. The control arms, struts, ball joints, bushings, bearings, steering linkage, boots, mounts, springs, etc, etc, are all worn together. When your car is sitting on the rack being aligned, there are no outside forces on the car. So putting the car in spec isn't the issue. As you begin to drive the car, the suspension as a whole is worn out, so it's sagging and flexing out of spec causing your tire wear issues. When the car comes back to a stop, LOL,, when it matters the least, the car is back in spec. Just replacing the struts might fix it for about 6 months, but the rest of the worn suspension will just wear that new strut out faster and you'll be right back where you started. If you putting 150 miles a day on your car for over a year and a half , then you've put an additional 55,000 miles on the car atleast just in the time you've owned it. So I would imagine that the overall mileage on the car is quite high by now. As metals flex they heat up and cool down, expand and contract. And can even become brittle. Weather conditions and road salts eat away at the polyurathane and rubber compounds. bearings begin to gap, and seize. Most of this isn't detectable by a visual inspection. And just measuring backlash alone won't tell you the overall state of your suspension. Your at the cost verses time crossroads. Are you going to keep the car for more years to offset the suspension replacement? or is it cheaper to just keep replacing tires until you get rid of the car? there are plenty of how to's here so you can probably save a boat load of money if you decide to do the work yourself. That is really the only cost effective way I can see doing this for a 15 year old car. But you could also be one of those people that will own a car for the rest of your life. If that's the case, then it's even more worth doing.
