QUOTE (code58 @ Nov 3 2009, 12:32 AM)
QUOTE
A good friend of mine is a master Toyota tech ... he recommends changing the belt at approx 105-110K on the 3.3L V6. I know others have recommended a longer interval, but I took my friends advice because it was relatively inexpensive (~$450 for belt/water pump) -- compared to a belt breaking. As usual, YMMV.
Did your friend give you a deal on that? That is extremely reasonable.
He lives in another state, otherwise he probably would have ... :-) But, this was an advertised special at a shop that specializes in Toyota/Lexus. The actual coupon was $189 for a timing belt replacement, however, if you add the water pump (and who wouldn't), it added about $250. Add in the serpentine belt and there you have it. Oh, and yes, they only use OEM parts ... I can't believe the dealer wanted $1200 .... wow.
