Nacmias
Nov 1 2009, 03:22 AM
Hi all. A month or two ago I purchased a 2000 ES300 for $4,500. I'm 20 years old, and my father owns a car dealership and a service center, so I got the car for what he told me at least $5,000 off. It is in very very good shape, paint, interior, engine all runs good, but it does has 130,000 miles. The problem is when I hit a bump, from the front of the car, when I hit a bump with either the left or right wheel, it makes a "clunking" noise. I do not think it is the struts, because the car does not bottom out or ride rough, but maybe the towers? Even on the little bumps it makes this noise. It sounds like the plastic shields are loose, but I have checked it and that is not the problem. My father is busy, so I don't want to bother him with what he calls "stupidity" but I would like to know what the problem is because I actually love this car and don't want it to fail on me. I hope someone can help me and can solve this annoying problem, annoying to me anyway. Thank you!
1990LS400
Nov 1 2009, 09:30 AM
It could be the "FRONT SUSPENSION SUPPORT NOISE" described in the attached TSIB. The same problem affected our 98 Camry. We put up with the rattling sound for several years since we were told it wasn't a safety issue.
I just now checked our records and see that the problem on our Camry was fixed in Spring 2005 for $350 (not including tax) by an independent repair shop specializing in Toyota and Lexus vehicles.
But, of course, the problem could be something else.
camlex
Nov 1 2009, 09:48 AM
QUOTE (1990LS400 @ Nov 1 2009, 10:30 AM)
Do you have any info for "REAR SUSPENSION SUPPORT NOISE" ?
Thanks,
1990LS400
Nov 1 2009, 10:05 AM
QUOTE (camlex @ Nov 1 2009, 09:48 AM)
I do not see any TSIB's in the Chilton online library for rear suspension issues on the 2000 ES300 or 1998 ES300. The Chilton library does not contain information specifically for the 1997 ES300.
kingjack133
Nov 1 2009, 11:32 AM
I would take it to a shop for a diagnosis and estimate, free ....hopefully!.Once you know for sure what the problem is, maybe it can be fixed at your dads shop where he can give you a break on cost and not rip you off or call you stupid? ....hmmm.....otherwise find a good shop.
kashi125
Nov 1 2009, 11:25 PM
At 130K miles, 99% chance it is your strut mounts. Does the noise get worse in cold weather?
yeskay
Nov 5 2009, 11:40 PM
either strut mounts or strut bumper. there are a lot of threads in this forum regarding this noise and it is a known issue with this yr model. i had similar issue and i replaced both of them.
