im wondering if it is normal for the 06 GS300 to consume a quart or two in between 5000miles oil changes?? is it normal to add oil in between 5k miles oil changes to add oil to keep the level above minimum??
im fairly new to this car..
GS300dude
Oct 31 2009, 12:28 AM
QUOTE (spine911 @ Oct 30 2009, 10:20 PM)
how many miles you have on the car? what is your driving style aggressive? normal? kaotic?!! .... i say thats not normal espicially for a 2006 model year....the car seems to burn out too much oil....
pauljcl
Oct 31 2009, 01:11 AM
QUOTE (spine911 @ Oct 30 2009, 11:20 PM)
The engine is the V6 that Lexus sprinkles in many of its models. My experience with an RX300 of 1999 (purchased 2003 with 45K miles, now 75K miles) is that I have never had to add oil between 5000 mile oil changes. FWIW!
John Stanley
Oct 31 2009, 06:38 AM
My 2006 GS300 RWD has 88000 miles on it, and doesn't burn a drop between oil changes. Stan
steviej
Nov 2 2009, 08:14 PM
QUOTE (John Stanley @ Oct 31 2009, 07:38 AM)
Nor does mine. I have 57,000mi on my clock. However, depending on who you talk to, some "experts" will say that this is an acceptable consupmtion of oil. Have you looked to see if there are any oil leaks or weeps? Do you have any hint of blue smoke especially upon start up?
The oil has to be going somewhere.
steviej
eatingupblacktop
Nov 10 2009, 12:08 PM
If you haven't been doing quarter miles for that 5k then I would say it's abnormal cunsumption. Put a tracer in your oil and see where it comes out. You can also pull a plug.
zooomer
Nov 12 2009, 12:22 PM
QUOTE (steviej @ Nov 2 2009, 09:14 PM)
steviej
I don`t know, just check my oil level and is the same thing. 2 month ago i add about 1/2 quart to make sure the level between the two dots and now is below bottom dot. I have no blue smoke in a mourning and engine is free of any leaks. May be it`s normal? Newer have oil check light. I will keep my eye on level now. How much exactly quarts should be in the you know? The oil I use Mobil 1.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
