Thundercow
Oct 28 2009, 03:08 PM
I changed out my 04 battery. I have the usual window problem now but some other problems as well. Please save me a trip to the dealer!
The one I can't fix is the cd player doesn't play, cannot be selected, and the power button on the radio cannot turn on the radio. I have an ipod adapter installed. This happened once before to me, and someone told me a trick that I cannot now remember.
joe913
Oct 28 2009, 04:49 PM
I am not sure, but you might check the secret menus at this link or search for others:
http://us.lexusownersclub.com/forums/index...showtopic=29792
joe913
Oct 28 2009, 05:27 PM
I have a document that helps to troubleshoot the 2003 model electrical system, including audio. If you think it will help, give me your email address and I will forward it to you. The file is larger than the 2MB maximum for this site. Good luck
Thundercow
Oct 28 2009, 05:45 PM
Actually, it was a reset sequence of some kind like disconnect battery for 20 minutes or something like that. But of course if I could remember it, I'd just do it.
ThisIsBob
Oct 30 2009, 05:55 PM
I'm getting ready to change the battery in my 2002 RX300. Has anyone ever used one of these to save the settings:
http://storeworth.com/product/9-Volt-Batte...mory-Saver.html? Do they really work?
carguy07
Oct 30 2009, 08:44 PM
QUOTE (ThisIsBob @ Oct 30 2009, 07:55 PM)
They work great on other cars but the RX kills the cigarette lighter when the ignition is turned off. Is there a plug in the back that is always hot? That might work. Whatever you do, do not kill the battery with the ignition switch on. Bad things can happen.
Thundercow
Nov 10 2009, 01:48 PM
Just to complete the thread...what worked for me was disconnecting the negative battery terminal for 5 seconds...everything was fine after that...
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
