Willing to make deals to local buyers who want both.
Rockford Fosgate T1500-1bd
* RMS Output @ 4 ohm: 500W x 4
* RMS Output @ 2 ohm: 1000W x 4
* RMS Output @ 1 ohm: 1500W x 4
* CEA-2006 compliant
* 24dB/octave crossover
* 4 Gauge power/ground terminals
* Audiophile grade speaker connections
* Infrasonic filter
* MOSFET output stage
* MOSFET power supply
* RCA pass-thru
* Cast aluminum heat sink
* Dynamic thermal magnet
* MEHSA(3) to reduce MOSFET temperatures, lower distortion, and increase durability and lifespan
* Punch Bass EQ
* DSM to increase circuit efficiency and eliminate cross-talk from other components
* Power, Thermal, Protect visual indicators
* Class bd circuit topology
* 2.14" x 8.14" x 14.91"
Rockford Fosgate T600-4
600W 4 Channel Amplifier
* RMS Output @ 4 ohm: 100W x 4
* RMS Output @ 2 ohm: 150W x 4
* 300 watts RMS x 2 bridged output at 4 ohms (2-ohm stable in bridged mode)
* Dynamic Thermal Management cooling system
* Differential Input circuitry eliminates hum
* Variable high- and low-pass filters (20-500 Hz, 24 dB/octave)
* Variable bass/treble boost (0-18 dB at 45 Hz, 0-12 dB at 12k Hz)
* Optional remote bass/treble boost
* Class-AB amplifier design
* MOSFET power and output stages
* Preamp inputs and outputs
* 14-15/16"W x 2-1/4"H x 9-5/8"D
