Hello,
My Engine Light and Trac Off light both came on and stayed on with a "whining" noise coming from the front of car. I took it to a repair shop and they did a Scan ECM for codes and Code #13 was found. They found that two sensors were out of sync and the Cams were out of time and when they looked at the timing belt about a quarter of an inch of it was gone (width wise). They took it apart and found that the bearing wheels that the timing belt sits on were bad (not sure it that is what they are called - pulleys?). One barely would turn, the other made noise. Also the tensioner was bad. They replaced timing belt, timing belt idler br and timing belt tensioner along with the two bearings (pulleys?) and reset the timing.
The total cost was $600 and would like to know if this is a fair price and if the problem sounds right? Good mechanics are hard to fine. I don't mind paying as long as it's fair and the work is accurate. Curious to know what kind of mechanic I used.
Thanks for any information,
Joe
