QUOTE (lexus_ne @ Oct 21 2009, 02:00 PM)
I'm thinking about changing the ATF on my 2000 RX3000 myself for the first time. I have read this excellent DIY post (http://www.clublexus.com/forums/rx-first-generation/220061-photo-diy-rx300-awd-transmission-fluid-pan-filter-change.html) and think I can handle it. I have several questions before rolling up my sleeves though:
* What type of ATF should I get?
* My rx300 only has 65K miles on it although it's almost 10 years old. Do I need to replace the transmission fluid pan gasket and filter? If yes, where is the best place to get the parts?
Cheers,
Jim
Are you the original owner, i.e. do you know the maintenance trail the vehicle has had ? If so, and the fluid has never been changed, I would start with a full system flush from a dealer...then start doing 4 quart drains yourself at regular intervals, very meticulous would be every 15K miles, up to 30K would probably be OK. It just depends on your driving habits and heat. After the full flush, you can then drop the pan later on to do a 4qt drain, and you will be able to inspect the screen/filter...unless you instruct the people who do the flush to drop the pan as well, but it would add to the cost.
I just did a 4qt drain on my "99 RX300 (I'm not the original owner, but know the maintenance trail because it used to belong to my mother-in-law, well-maintained with T-IV fluid) and dropped the pan and changed the filter. I added 4qts of Mobil 1 Synthetic. I believe I have noticed slightly smoother shifting, and less tendency for the tranny to hesitate between the 1-2 shift point under very light acceleration, like slowly driving in a neiborhood looking at houses. I have no empirical proof of this, strictly "seat of the pants" feel. I also admit to being biased toward synthetics, and have been using them in all my vehicles since 1995.
BTW, the tranny filter was not easy to find. There are two types made for these trannys, fillters with a round pickup tube, and those that are square. Mine was the round one, and I finally found a Purolator one at Pep Boys. Hope this helps.
