Help - Search - Members - Calendar
Full Version: Those Plastic Engine Covers
Lexus Owners Club (USA & Canada) > General Lexus Forums > General Lexus Discussions
LeodLion
We bought a 2010 RX 350. This is the first time I have a car with those plastic engine covers. So I took them off to take a look at the engine compartment. Then I put it back. I noticed the small plastic tabs were tight before but after putting them back on, they were loose and some of the plastic cover were not in there tight.
So what are the purpose of this plastic engine compartment covers? I can think of noise reduction perhaps, protect from dust and dirt? Make the engine compartment neater? Reduce noise? Or is it a nuisance because it may create some rattle and you have to take them off and back on when you work/inspect the engine.
1990LS400
You have listed all the reasons plastic engine covers are used on many if not most cars these days.
Cars have become relatively low maintenance. The plastic engine covers on my LS have been removed only twice that I know about in 115,000 miles / 9 years -- at 90K to replace the timing belt and last Spring to replace the TPS and PPS. They will come off again at 120K for the first spark plug replacement.
What is it under the covers that you are going to need to frequently work on or inspect?
LeodLion
QUOTE (1990LS400 @ Oct 19 2009, 10:03 AM) *
After the warranty period I will do most of the maintenance myself. I may install aftermarket stuff in the engine compartment. I want to look around and check things are okay.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
