Help - Search - Members - Calendar
Full Version: Steering Wheel Fantasy...
Lexus Owners Club (USA & Canada) > Lexus Owners Club > Lexus SC300 / Lexus SC400 / Lexus SC430 Forums > 92 - 00 Lexus SC300 / SC400
Ted7
Ok, I'll try to explain that the best I can.
When I go straight ahead, my steering wheel is straight.
If I turn right, then go straight, my steering wheel is 15° tilted to the right.
If I make a left turn, then go straight ahead my steering wheel is normal again.
Alignment has been made, didn't fixed the problem.
When I turn the steering wheel there is no suspect sound (no "clongs" nor whatsoever).
If I go straight and release the steering wheel, the car doesn't move from its trajectory...
Question:
  • Is there something to tight between the steering wheel and the rack and pinions?
  • Is it a problem with rack and pinions?
Thank you in adevance for your help
T7
GrnHrnt
QUOTE (Ted7 @ Oct 18 2009, 11:50 PM) *
Question:
T7
Steering wheel movement should be smoothly transmitted to rack and pinion input shaft. Check steering column for binding and inspect two "universal" style couplings on steering column.
Ted7
QUOTE (GrnHrnt @ Oct 23 2009, 04:28 AM) *
Thanks... I've seen my mechanic, I'm good for a rack & pinions change.
$450,00 all inc.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
