Help - Search - Members - Calendar
Full Version: Disappearing Electrics
Lexus Owners Club (USA & Canada) > Lexus Owners Club > Lexus GS300 / Lexus GS400 / Lexus GS430 / Lexus GS 460 > 06 - 09 Lexus GS300 / GS350 / GS430/ GS460
RicHallgren
I have a GS300 that has travelled 136000Klms without mechanical or electrical incident .
Over the last few days it has momentarily lost all electrical power. The first two times it was very quick, all the intruments, lights, radio etc lost power but the motor kept going presumably because the power cut was very short.
The last occurence seemed to be about two seconds. All power was lost and this time the motor stalled.
I rolled to the side of the road. All power had returned and the car started without difficulty.
I have checked the battery, "jiggled" the cables, fuses, relays etc.
I cannot bring the problem on and each time it happened was in normal cruising driving, gentle acceleration etc.
PLEASE, has anyone experienced this problem or have any ideas?
Ric
JMBGS300
QUOTE (RicHallgren @ Oct 12 2009, 03:35 PM) *
Ric
Have the battery checked out in detail. I had a similar experience in a Volvo where the power dropped as I stopped the vehicle a few times. Later under gradual acceleration and up a hill all power was lost and the engine quit. This time I could not start the car and had to have it towed. Turns out one of the many plates in the battery had come loose and had touched a neighboring plate shorting out the battery. They tell me the earlier power outages could be attributed to the plates briefly touching but not making permanent contact. The plate support finally gave way and contact between plates was constant rather than occasional.
Worth having them check the battery. 136000 miles maybe its time to treat yourself to a new battery. dry.gif
RicHallgren
QUOTE (JMBGS300 @ Oct 12 2009, 08:51 PM) *
Ric
Thank you. The battery is only 18 months old but I guess that is no guarantee. I will swap it over and see what happens.
Thank you for the response
Ric
JMBGS300
QUOTE (RicHallgren @ Oct 13 2009, 12:25 AM) *
Ric
Ric
My Volvo was 4 months old and I suspect the battery not much older. It was just a faulty build and didn't have any issue with length of use. Good luck.
dpark
QUOTE (RicHallgren @ Oct 12 2009, 08:35 PM) *
Ric
Did you every get to the bottom of this issue? Having something similar happen with my GS300. Dealer can't figure out what the issue is after 3 days!
Thanks!
steviej
sounds more like a faulty ground connection rather than a battery.
steviej
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
