QUOTE (pauljcl @ Oct 11 2009, 11:20 PM)
QUOTE (Pete P @ Oct 12 2009, 12:11 AM)
I cannot open my hatchback unless I do it manually. The remote and the button by the steering wheel will not work either. Also, once it is opened manually, i cannot not close it by pushing the button under the hatchback door or by using the remote. I have to close it manually. Could it be a fuse? If so, does anyone know where that fuse is located?
Thanks
Pete
The reply probably is in the manual, which you can access on line after registering at Lexus.com if you wish to do so. I would note that there is a button (was it in the glove-box?) which prevents the rear hatch from power operation. You should check if it has been pressed or set accidentally. Good luck!
Wow you know what? I changed the cabin filter yesterday and I remember that button. I remember thinking "hmmm what is this button for? let me press it to find out" I pressed it a bunch of times. That must be the problem.
Thanks! I was ready to take it to the dealer and pay them 1 million dollars to push the button for me. I will go check it now
