Greetings fellow SC430s...
I recently installed a Dragon (Secret) Weapon-R cold air intake on my 2002...
At first things work well for a couple days, then the Engine Check, VSC, VSC OFF lights came on & stayed for a day or so after I accelerated somewhat agressively... but after a day or so (3 trips) the lights went off. But then a few days later all 3 came on again & stayed on longer before turning off, and now they are on & remain on. And on top of that I've had several bouts of difficulty starting, especially restarting after a drive (i.e. running an errand).
I bought an OBD tool to read the code, which it turns out is PO340 (Camshaft Position Sensor A Circuit Bank or Single Sensor).
I have no idea what means or what the implications are. Any suggestions?
Is this a coincidental malfunction of some kind or did something get messed up with the cold air intake install?
From what I could gleen on the Net is the following things might be affected:
- battery
- poor gas quality (fix with chevron techron fuel injection cleaner?)
- brakes/rotors
- brake fluid level
Any & all advice would be appreciated. Many thanks in advance!
