I have the rubber all weather mats....held in place with the hook.
Dunno if they are supposedly causing a problem also.
3.8 Million Toyota, Lexus Recalled Over Floor Mats
The National Highway Traffic and Safety Administration issued a wide-ranging recall late today for 3.8 million Toyota and Lexus vehicles. The recall stems from faulty floormats that can become stuck under the accelerator pedal causing unexpected acceleration. The defect is suspected to be the cause of one recent fatal accident.
The recall includes the following models:
2007-2010 Camry
2005-2010 Avalon
2004-2009 Prius
2005-2010 Tacoma
2007-2010 Tundra
2007-2010 ES 350
2006-2010 IS 250 and IS350
NHTSA suggests all owners remove the driver-side floormat from these cars immediately and not replace them with anything. Toyota has released a warning for owners including steps to take in case of an accelerator issue. We've posted the notice below.
Toyota Notice
Should the vehicle continue to accelerate rapidly after releasing the accelerator pedal, this could be an indication of floor mat interference. If this occurs, Toyota recommends the driver take the following actions:
First, if it is possible and safe to do so, pull back the floor mat and dislodge it from the accelerator pedal; then pull over and stop the vehicle.
If the floor mat cannot be dislodged, then firmly and steadily step on the brake pedal with both feet. Do NOT pump the brake pedal repeatedly as this will increase the effort required to slow the vehicle.
Shift the transmission gear selector to the Neutral (N) position and use the brakes to make a controlled stop at the side of the road and turn off the engine.
If unable to put the vehicle in Neutral, turn the engine OFF, or to ACC. This will not cause loss of steering or braking control, but the power assist to these systems will be lost.
-If the vehicle is equipped with an Engine Start/Stop button, firmly and steadily push the button for at least three seconds to turn off the engine. Do NOT tap the Engine Start/Stop button.
-If the vehicle is equipped with a conventional key-ignition, turn the ignition key to the ACC position to turn off the engine. Do NOT remove the key from the ignition as this will lock the steering wheel.
In the event owners choose not to remove their floor mat, Toyota strongly recommends that they ensure that the correct floor mat is being used, that it is properly installed and secured, that it is not flipped over with bottom-side up, and that one floor mat is not stacked over another. Information on proper floor mat installation can be found on
http://www.toyota.com and
http://www.lexus.com.
Owners with questions or concerns, are asked to please contact the Toyota Customer Experience Center (1 800 331-4331) or Lexus Customer Assistance Center (1 800 255¬3987), or consult the information posted at
