Help - Search - Members - Calendar
Full Version: Navigation Dvd Installation
Lexus Owners Club (USA & Canada) > Lexus Owners Club > Lexus RX300 / Lexus RX330 / Lexus RX350 Forums > 07 - 09 Lexus RX350
smiley47
How difficult is it to install the Nav DVD update? My dealer is charging $200 for the DVD and $150 for the installation labor. I've heard it takes only 5-10 minutes to install.
Any comments on the installation process would be appreciated.
Claude7629
QUOTE (smiley47 @ Sep 28 2009, 04:57 PM) *
1) Remove rear tool tray( NAV DVD player is underneath)
a)fold down rear seats
b)find velcro tabs on each side of rear tray cover where it meets back seats
c)lift velcro tabs
d)slide fingers gently along edge where rear cover meets rear seats to release 5 plastic push pins.
e)Use 12mm socket to remove the 2 now visible hinge bolts
f)remove tool tray cover
g) remove tool tray, There are 2 black push pin on both sides that pry up easily. NAV DVD player should now be visible on passenger side
2) Put ignition in ACC position
3) If there is a dust cover on unit remove it. Mine did not have this. Some do.
4) There should be a "slide type button" on your left of the unit. Slide this button to your left(facing unit). DVD should eject
5) Insert new DVD
6) Slide button back to original position
7) allow NAV to update before turning off ignition( check NAV Screen)
8) Reassemble in reverse order.
Hope this helps. I just replaced mine in a 2008 RX. It may sound like a lot , but I was finished in 15 minutes.
Tip: If you are uncomfortable with DIYs, take your time and think it through.
MBman
i'll do it for $50 (lol)
Should take all of 5 minutes, I would report your dealer to lexus headquarters!
smiley47
QUOTE (Claude7629 @ Sep 28 2009, 05:16 PM) *
c)lift velcro tabs
5) Insert new DVD
Thanks Claude, mine's an 08 RX too so it should be a snap.
Grampa-2007
QUOTE (smiley47 @ Sep 28 2009, 09:24 PM) *
c)lift velcro tabs
5) Insert new DVD
Tried the above but, how do you get the DVD out? Slid the slide button to the left and the DVD did not eject.
Thanks for any help in this matter.
metal
QUOTE (Claude7629 @ Sep 28 2009, 07:16 PM) *
c)lift velcro tabs
5) Insert new DVD
Great info...thank you. BTW, where do you suggest getting an updated DVD and what changes can be expected vs current (2008) DVD?
crushercoors
I like that I should be able to replace the navigation DVD in my 2009 RX350 myself (Is the procedure the same?); thanks for the advice smile.gif . $200 seems like a lot for a DVD; is there a better place than my dealer to purchase the DVD (like maybe some web store - Amazon or something)?
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
