QUOTE (JWhite @ Sep 25 2009, 09:50 PM)
I called the Lexus dealership today and was told the tramsmission has a total of 7 solenoids and wanted to know which one was bad. I told them I had no idea but said I had the code that said that was the problem. I would assume the code would say which one it is or am I wrong? They said they couldn't tell by the code and the transmission would have to come out for them to know which one was bad. Couldn't they test drive it and tell when thetransmission was not shifting when it should. Blake918, you said your #3 solenoid was bad, had did you know that? I am kind of stuck if I go to the Lexus dealership because that is the only one her in Las Vegas. I will check around with some transmission shops and see what they have to say. By the way, Lexus said the solenoids range from $ 250.00 to $ 500.00 each depending on which one.
You are correct, the code tells you which solenoid might be bad. I had a PO763, and the repair manual tells me that is the #3 solenoid. The repair manual says that a 770 is the Shift Solenoid Valve SLU. The text pretaining to the 770 code says that the SLU deals with clutch lock up, so I think this might be the part number 35280-50010, but have someone verify it for you (not your local dealer. I'll list some links below to reputable dealers that we buy parts from). If I did happen to stumble upon the correct part number, that solenoid is $268 at Park Place.
This is where I got the part number from:
http://www.toyodiy.com/parts/p_U_1995_LEXU...EPGKA_3512.htmlI bought my solenoid from Park Place Lexus in Texas. The Assistant Parts Manager (sent him an email through their website) was more than helpful in ordering the correct part for me. It was painless. These are the dealers that I use for parts. Park Place is probably my favorite. I've been buying from them for more than 6 years. Their prices aren't always the lowest, but their customer service via phone or email has always been first rate.
Park Place Lexus:
http://www.newlexusparts.comSewell Lexus:
http://www.sewellpartsonline.com/select.asp?cat=BODYThompson Lexus:
http://irontoad.com/l_home.htmCarson Lexus:
http://www.trademotion.com/partlocator/ind...m?siteid=214915(Carson is in Southern California, so they could probably get the part to you the quickest. PP and Sewell are in the Dallas area, and Thompson is in Pennsylvania.)
And here's a picture of my transmission (might be slightly different from yours since I have a 5 speed), but you can see 5 solenoids staring you in the face on the left side, and there are 2 more on the right side that are not really shown in the pic. And the new solenoid (I want to say this one was about $240 out the door.)..
Click to view attachment Click to view attachmentThis is for my '99, so the testing procedures may not apply to your '95, but here it is anyway:
