cherrypik73
Sep 22 2009, 07:54 PM
Hi everyone,
I have a 2007 GS 350 AWD with run flats that needs tires before the winter. I like to purchase the Michelin® Pilot® Sport A/S Plus. Can anyone confirm Michelin® Pilot® Sport A/S Plus are run flats? If not, do I have to purchase a special sensor for each tire?
Other tire recommendations are welcomed...
Thanks!
steviej
Sep 24 2009, 09:44 PM
They are not run flat tires but they are an awesome tire.
when you replace the tires, you do not need to replace the TPMS sensor. This sensor is incorporatated into the valve stem assembly and is attached to the rim. However, when you replace the tires, it is a good practice to replace the gromets and o-rings in the valve stem/TPMS. Any good tire shop will be able to do this. You do not need run flat tires for the TPMS system to work.
I actually dumped my run farts last year for a set of the Pilot Sport A/S (on 18" rims for spring thru fall) and 17" Pilot Alpin PA3s strictly for winter use.
steviej
cherrypik73
Sep 25 2009, 10:34 AM
Thanks for the info Stevie. Should costco know this or should I remind them?
Also, the dealer recommended that I get an alignment. Is it necessary after a new set of four tires?
Paul
steviej
Sep 25 2009, 10:18 PM
Costco should know what to do with the valves, it is a very common and recommended practice.
If they have no idea what you are talking about then take you business elswhere.
The alignment doesn't hurt, is good to do and for the price is worth the investment.
My tire shop offers a free alignment check with the purchase of a new set of tires. If it is out of spec, then they will ask me if I want it done. If they do it, then it is $79.95 for all four tires.
steviej
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
