Help - Search - Members - Calendar
Full Version: 225/70/16 To 225/60/16 On 2000 Rx300?
Lexus Owners Club (USA & Canada) > General Lexus Forums > Wheels and Tires Forums
OzCoLexus
The 225/70/16 are of course the stock size. I have a chance to pick up a set of 225/60/16 worth the money in like new condition. I'm not worried about the speedometer reading, but I am concerned about the clearance of the tire. Can anyone tell me if they are close enough to work fine? Also, I would still have the 225/70/16 spare for the life of the tires. Is this a major deat on an AWD if it is only temporary? Thanks for the help.
2JZTWIN TURBO
QUOTE (OzCoLexus @ Sep 16 2009, 10:48 AM) *
It should fit. The width of the tire will remain the same however the height from rim to tread will change from 70% of 225mm to 60% of 225mm.
pauljcl
QUOTE (OzCoLexus @ Sep 16 2009, 11:48 AM) *
Clearance to the car body will be fine, but clearance to the ground will be reduced. Of course, the smaller circumference of the tire will result in a faster motor rpm for a given speed, somewhat faster acceleration, and more miles/kms indicated on the speedometer and the total mileage. You might be interested in checking out the site below for comparison of tire sizes:
http://www.miata.net/garage/tirecalc.html
Good luck!
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
