QUOTE (katzjamr @ Sep 15 2009, 03:11 PM)
chimchim, when toyota did research on hybrid cars prior to the first 400h they found that Lexus owners at that time had two major concerns, first they didnt want to give up luxury for the hybrid experience, and two they didnt want to worry about the battery. Toyota knew at that time the our batteries would last longer if they were never fully charged or depeleted say beyond the last 30 or 40% of their charge. So the algorithm that maintains this range was set up to protect the battery in that way and toyota could give you a seven year 100k hybrid warranty (longer in california). Some of us wish the charging system was more adaptable and there have been improvements in the later models however until the next generation battery is available this is the way its going to be. There really isnt any way to change how the 400h decides when and where to charge or discharge the battery. also keep in mind everything is running off the main battery once the car is started, so the drain of accessories, the need to keep the catalytic converter at a high temperature for low emissions, how much cabin heat you desire, is the ac on all factor into the battery charging, engine running equasion.
Using cruise control will be more efficient than not as the system works more seamlessly. ifyou turn off some accessories the battery stays charged longer and is more efficient. in seattle our weather is mild and i open the window or the sunroof and have all fans off and of course no ac at all. this always improves my mpg.
as many have said these benefits show up in city driving more than hiway, also do have the dealer at the next service check the isc learning to see if it is set correctly, there is a tsb here if you do a search and they will know what you are talking about. if you have a battery that is not original, or any work was done where the battery was disconnected this system may be out of adjustment.
Ahhh... that answers a lot of my questions. Thanks for the reply!
My experience with the car does jive that the car is erring on the side of making sure all systems are fully ready to keep luxury up in sacrifice of hybrid optimization
I'll check on the TSB for the ISC learning
As for the accessories, I noted similar behavior when our return trip was at night (so no A/C), windows up, heater off, and even the stereo off, cruise on.
I understand that city better utilizes hybrid technology
I wish there was a "advanced user" hybrid selection control deep in the menu screen or something that would allow me to say "no matter what I do, go aggressive on electric use", and if that means I get a warning bell saying "I can't give you A/C", etc.
