Well I really inspected everything on both sides. Both doors are identical so there is nothing wrong or bent in the door itself. Smooth1 to answer your question the clearance of the door on the passenger side is the same as the drivers side. If I look at an angle the amount of space is even across the door except it gets tighter uptop. One thing that clued me into the door being off is that the weather stripping is creased all around the top, the door seals fine and is easy to close but the weather seal is basically crushed meaning that after years of the door being out of alignment it put too much pressure on the weather stripping and permanently creased the seal. One thing I should also mention is the the front passenger door is also pushed more in compared to the drivers door, the weather stripping around the door is also showing creasing although not as bad as the rear door.
After further inspection comparing both sides of the car I found that the bottom of the passenger side doors seem to protrude out more compared to the drivers side. It's not much but it is noticable if you run your finger across the botton the door over the gap between the door and the sideskirt. The drivers side is flush or the door is recessed slightly back, on the passenger side the door is slightly overlapped. I'm now beginning to believe this has been a factory installation problem with the door itself. The question is how to I adjust the door the fix this? I was thinking of loosening 3 of the 4 bolts that hold the door on the hinge leaving all but the very bottom hinge bolt. I would then pull back on the door and and tighten it all back up. It just needs to rotate outwards on a horizontal axis. I may be exagerrating alittle when I said 3/4 of an inch. I did measure and the the door is recessed about 3/8 and inch away from the body where the drivers doors are only recessed less than an 1/8 inch away.
QUOTE (smooth1 @ Sep 12 2009, 08:11 AM)
I went out and looked at mine, I see where your having your issue. 3/4 of an inch is alot! Mines flush on both sides. So I can see where your visually bothered by this. I would be to. So let me ask this, if you look down at an angle and try to see behind the edge of the door, is the amount of space about the same all the way down the door also? or does the edge of the door right there seem alot closer to the quarter panel? If it looks alot closer right there, then it's bent and can be fixed pretty easily by a body pro with some banging and bending. I would let them fix it, you don't wanna crack or chip your paint. It won't effect the door seal or fitment as this part of the door is more of an overhanging edge and the actual seal is well inside. I can easily see how this part of the door can be bent or pushed in without effecting any other part of the door. I don't see someone bending it 3/4 of an inch, but it looks to me like it could be from just using this area of the door to push on to close the door. Maybe as years went by and repeated use? But I think somehow this part of your door just got pushed in by something.
