QUOTE (Premium Package @ Sep 4 2009, 12:59 AM)
Hi,
I have a 2007 LS-460L, went to check the tire pressure before this weekend road trip. Tire pressure reading on muti-information display is off by 5+ PSI then reading from hand held tire gauge. Wanted to do a reset. Search all around below driver steering wheel, above right knee and I cannot locate the reset switch. It's in the owner's manual but I can't locate that darn little button to hold for three seconds. Do I need new glasses or am I missing something?
Have a safe and happy Labor Day weekend.
TIA
Waaait!! You don't understand what you are doing and you may cause yourself a lot of grief. The accuracy of the TPMS has nothing to do with the "reset" switch. The accuracy is solely dependent on the accuracy of each wheel sensor - there are five (4 on the ground and the spare). The wheel sensors are typically very accurate and each is completely independent of all the others. It is possible that you have some sort of display problem, but that is unlikely.
I suggest that you check the accuracy of your hand held tire gauge as that is the most likely source of your problem.
The "reset" switch is for establishing a "tire pressure benchmark" in the car's computer that is used to calculate the low-pressure-warning thresholds. The benchmarks for all five tires are established when the "reset" is activated. If you reset the benchmarks improperly you may cause the TPMS to alarm when the tires are not low, or, you may cause the TPMS to fail to properly warn you of a low tire.
