QUOTE (afr221 @ Aug 28 2009, 09:25 PM)
QUOTE (gridlock13 @ Aug 28 2009, 10:20 AM)
in the 2006+ GS's they said the drain hose was clogged or somehow got moved and it was pouring into the cabin. try getting under your car and looking under the b-pillar (between where your front and rear doors meet). i think this was the solution?
This would the drain hose from the sunroof?
In the '06 most commonly that would be the drain hose from the air box under the dash that houses the AC evaporator. The 2006+ has a very weird configuration and the hose often and easily gets clogged, dislogged or disconnected. The hose exits the box and then goes out through the firewall. If it does not drain out though the firewall, then it will drain inside the cabin. The water runs under the carpet and is noticed when it soaks through. There is even a TSB for it:
AC003-07 DEC 07: A/C - Water on Front/Rear Carpets.
steviej
