QUOTE (NicLX470 @ Aug 10 2009, 12:43 PM)
Out of my maintenance manual for my IS350.....
Transfer Case/Transmission:
The transfer case/transmission
and transmission fluid are a completely
sealed unit. Therefore, periodic
checks and replacement of the transmission
fluid are not required, and
there is no dipstick on the transmission.
Any repairs that require adding
or replacing fluid should be performed
by a qualified technician following
procedures in Lexus service
and repair publications.
So pretty much they are saying you do not have to change the transmission fluid...ever? But you can if you want? I will definitely want to change the transmission fluid. At what mileage would it be appropriate? Southeast Texas where temperature is well over 90F 75% of the year.
ALL transmissions require service. Heat is the enemy of lubricating oils. The rule of thumb in the past has always been about 15k miles. BMW does the same thing. I had an older 5 series, in which the tranny had never been serviced. At about 125k miles, the trans started to go. When I found a reputable transmission shop, (interestingly enough, a former BMW certified mechanic), to rebuild it, (to the tune of $3200), he told me that the car manufacturer knows that the trans will last, in most cases, at least 100k, and by that time, the car will be out of warranty, and as a result, they are no longer responsible to make the repairs, but they certainly reap the rewards of those who come in to have the trans rebuilt. My suggestion, if you are planning to keep the vehicle for an extended period of time, is that you find a good reputable independent mechanic, and have the tranny serviced on a regular schedule.
