AKoos
Aug 9 2009, 05:41 AM
Just bought my first ever Lexus - after a Porsche Boxster, BMW 330, and most recently, an Infiniti M35....and I'm pretty convinced that this could be the best car I've ever owned. Just a couple things I'm trying to fix (this is the first of two threads)....
I can't stand how the daytime running lights are a pale yellow. I either want to somehow disable them - or change the bulbs. First off, opinions, anyone?
Secondly, if the answer is to somehow disable them, what's the "how" in somehow?
Thanks in advance....
1990LS400
Aug 9 2009, 07:04 AM
I thought a Lexus dealer could disable the DRL on a GS with a hand held tester but I don't see it in the attached list. You might check your owners manual or ask a dealer -- or maybe another GS owner will respond here to your question.
Did none of the cars you listed have DRL? I know my next door neighbor's Boxter doesn't and I don't think the M35 I rented for 10 days had DRL -- may not be remembering. I don't remember seeing any BMW's with DRL.
I suppose you could put some of those whiter halogen bulbs in the the DRL but those bulbs have a far shorter life.
Or you could get used to it. I certainly don't mind the yellowish tint of the DRL in my 00 LS -- got more important things to think about. I've been a big fan of DRL since the 1960s when I followed the initial DRL tests in northern Europe ... driven with headlights on or DRL during the day ever since.
One handy feature of Lexus DRL is that they provide adequate light to see in covered parking garages and tunnels during the few seconds it takes for the automatic headlights turn on. One of my favorite features of my LS is that I can leave the headlight switch in the "Auto" position and never touch it.
Regardless of what you do with DRL, review the attached list and see if there are any settings you want changed.
cduluk
Aug 9 2009, 11:21 AM
That particular halogen tint DRL is a Lexus thing. You can identify a Lexus from a mile away based on the DRL's. I think it's sort of like a signature. There aren't any other cars out there with that DRL color.
You'll get used to them. But if not, you can switch to a whiter bulb like philips xtreme. They're halogen, but produce a whiter light. But during the day, you won't even be able to see them since they're the same color as daylight.
jcrome04
Aug 9 2009, 11:27 AM
Sylvania Silverstar!
cduluk
Aug 9 2009, 11:41 AM
QUOTE (jcrome04 @ Aug 9 2009, 12:27 PM)
Eh, the Silverstar's aren't that much whiter than standard halogen's.
Especially because DRL's are regular halogen bulbs run on half the voltage. Silverstar's won't look any different than the standard DRL bulbs in DRL mode. In high beam mode however they will look brighter, but that's not what the OP is concerned about.
If you were concerned about brightness in high beam mode, i would suggest toshiba HIR bulbs. They are MUCH brighter than the standard halogen bulb, but again, at half voltage they'd look the same.
Philips xtreme vision bulbs have a whiter light, and i think t half voltage they'd be a little more white. It's the most 'white' halogen bulb you're ever gonna find without going HID. But that's impossible in a DRL/high beam unit.
SW03ES
Aug 9 2009, 12:36 PM
Changing the bulbs isn't going to make that big a difference. The DRLs are simply the high beams on low power, the reason they are yellowish is because they are depowered. I replaced mine with Silverstars and when the high beams are on I can definately tell the difference...but the DRLs look the same.
You'll get used to them...
AKoos
Aug 9 2009, 03:02 PM
Great help guys - I really appreciate it.
The Boxster didn't have any DRL's. The BMW did, but I had them disabled by the dealership and had them keep the Halo's on. The M35 never had any - not sure why - but I figured they would. Speaking of, I hated that car. Had to add that comment.
I think that I'll wait for a little bit and see if I get sick of the DRL's on the Lexus. If so, I'll just upgrade to whiter bulbs like the ones suggested. But I'd never really thought about the fact that they'd help in parking garages. I noticed it the other day when I was in one - but I guess it just never occurred to me that, if I got rid of them, that I'd end up having a different problem.
Thanks again!
blake918
Aug 9 2009, 03:52 PM
QUOTE (SW03ES @ Aug 9 2009, 01:36 PM)
QUOTE (cduluk @ Aug 9 2009, 12:41 PM)
I'm glad yall posted this! I've always thought about changing my highbeams to get whiter DRLs, but now I know not to waste the time or money!
NicLX470
Aug 9 2009, 04:33 PM
QUOTE (AKoos @ Aug 9 2009, 04:02 PM)
Thanks again!
I don't like them that much either on my IS350 or LX470. So I roll with the headlights on all the time. My HID lights even look great in broad daylight. They will go off immediately after the car is off and the driver door is opened so you will not have to worry about leaving them on in the day time. Just tell the dealer that and instead of them staying on for a while they can program them to turn off immediately.
SW03ES
Aug 9 2009, 05:00 PM
Thats great until an HID bulb or ballast goes from all the additional use and the bill is several hundred bucks...
cduluk
Aug 9 2009, 11:06 PM
The factory denso ballasts probably woudn't burn out even if you had your headlights on 24/7... The bulbs however will live a sorter life. Not a big deal, you can get a new pair for $50 on ebay, they're so common nowadays... It's the bulbs in the console, parking lights and tail light bulbs that would be costly to have to be replaced...
Duckman
Aug 10 2009, 06:15 AM
QUOTE (cduluk @ Aug 10 2009, 12:06 AM)
I don't turn on my headlights during the day and still had one of my HID lights burn out before 35,000 miles. My dealer replaced it under warranty, but I had thought the life of the new HID bulbs was supposed to be a lot longer than a standard bulb. It was weird too....got home and the light reflecting off the garage wall seemed a bit "pink" in color. Looked at the light and sure enough....a dark pinkish color. 2 days later...light out.
--Duckman
NicLX470
Aug 10 2009, 09:45 AM
QUOTE (Duckman @ Aug 10 2009, 07:15 AM)
--Duckman
They usually do but there is always a bad egg and your car happened to get that one. And yes a xenon bulb will turn from a pinkish to redish color before going out.
NicLX470
Aug 10 2009, 09:50 AM
QUOTE (1990LS400 @ Aug 9 2009, 08:04 AM)
I've heard that the dealer CAN disable the DRL's but I have read on a few forms on here that some dealers will do it with no problems but others say they can't because it's a safety issue. So it's worth a try.
cduluk
Aug 10 2009, 03:24 PM
HID bulbs should last about 3,000 hours before needing to be replaced.
The ballasts however should last forever.
Theoretically you should change your HID bulbs (whether dead or not) every few years, due to the fact that they lose a lot of light as they age.
AKoos
Aug 10 2009, 09:05 PM
Asking the dealer was my first try before he directed me to this forum, actually. They wouldn't do it for <ding> security issues. Way to hit that nail on the head.
NicLX470
Aug 10 2009, 10:49 PM
QUOTE (AKoos @ Aug 10 2009, 10:05 PM)
Haaa sorry that wouldn't do it for you!!
SW03ES
Aug 11 2009, 06:33 PM
Actually the life of an HID bulb is WAY longer than 3,000 hours...they are "supposed" to last the life of the vehicle. No filament to burn out.
The ballasts do fail though, and so do the bulbs.
cduluk
Aug 11 2009, 09:33 PM
QUOTE (SW03ES @ Aug 11 2009, 06:33 PM)
Yeah, 3,000 hours is a short time but that's the manufacturer's estimate for the lifespan, at least before they should be replaced. HID bulbs lose a LOT of light as they age. After 1,000 hours they've got the intensity of standard halogen bulbs...
I've spent quite a lot of time on hidplanet.com, where they talk about HID retrofits and everything HID. The best ballasts are the denso ballasts used on all of the toyota and lexus models. They're practically impossible to kill. I've heard of maybe one or two cases of them burning out, just anomalies though.
SW03ES
Aug 15 2009, 09:42 PM
You have some sort of source to back that up? I don't buy it. My HIDs are 6 years old and probably have more than 1,000 hours of life on them and are MUCH brighter than halogen bulbs.
1,000hrs is significantly less than the life of a halogen bulb...
cduluk
Aug 15 2009, 10:56 PM
QUOTE (SW03ES @ Aug 15 2009, 10:42 PM)
HID bulbs lose brightness and change color over time, it's called color shifting. An HID bulb after 1,000 hours emits the same amount of lumens as a brand new halogen bulb. It's from HIDplanet.com.
There's a graph that shows lumen output over time of the 85122 philips bulb. The curve has the greatest slope from new-1,000 hours and levels off.
1990LS400
Aug 16 2009, 07:35 AM
Osram is quoted in
http://en.wikipedia.org/wiki/Headlamp as stating that HID bulbs have an average service life of 2,000 hours.
Let's do some math.
The trip computer in my 00 LS400 indicates that my average speed over time is right at 30 mph.
My 00 LS400 just hit 113,000 miles on its original HID bulbs.
I estimate that my HID headlights are on far less than 20% of the time I drive but I will use 20% just to be pessimistic.
((113,000 * .20) / 30 mph) = 753 hours on my original HID bulbs
2,000 hours - 753 hours = 1,247 hours of life left on my HID bulbs
My HID headlamps still put out a very nice amount of light and are pleasantly brighter than the halogen lights in our Camry or the halogen lights in cars we rent. I suspect the original HID bulbs will last the life of the car.
SW03ES
Aug 16 2009, 12:10 PM
And whats the background of HIDplanet.com?
cduluk
Aug 16 2009, 08:06 PM
I've been an active member on HIDplanet for about a year, i've done 3 HID retrofits, used 4 different types of bulbs, i've read enough to know the lumen vs time values of an 85122 philips bulb...
Go find the graph, it' somewhere on there... It shows the curve of the philips 85122, 85122+, 85122WX and halogen bulb lumen values vs time.
SW03ES
Aug 16 2009, 09:57 PM
I've been to the site...I'm just not convinced that its a truly accurate and unbiased source of information...
All light sources dim as they age, but the light output of an HID system being equal to a halogen system at only 1/3 of its predicted life? I just don't buy it.
cduluk
Aug 17 2009, 09:24 AM
According to the manufacturers site, after 2,000 - 3,000 hours the bulbs should be at the end of their life. After 2,000 hours HID bulbs should still be illuminated, just not producing as many usable lumens of light as they started at.
They recommend HIB bulbs be replaced every 2 years or so because of this loss in light. You don't "need to" (not many people know about this standard) but it's recommended by the manufacturer.
I'm not making this stuff up lol...
1990LS400
Aug 17 2009, 09:53 AM
QUOTE (cduluk @ Aug 17 2009, 10:24 AM)
Steve/SW03ES, sometimes using logic is a waste of time.
SW03ES
Aug 17 2009, 10:48 AM
Then why don't you point me towards where a respected OEM manufacturer of HID lights (like Phillips) says that they should be replaced every 2 years? I have NEVER heard that, in fact I have repeatedly heard from automobile manufacturers that they should last the life of the vehicle.
Thats just preposterous! If thats the case then why does Philips sell an HID bulb that has the color characteristics to match an older bulb so you can only replace one...if they should just be replaced every 2 years as per the manufacturer. I've had HID lights on cars for nearly 200,000 miles and they were still putting out more light than halogen bulbs...I know because I have cars with halogen lights to compare them to.
I'm not saying you're making this up, I just have a feeling this info comes from some people on the HIDplanet forum that either don't really know what they are talking about, or they are talking about cheap aftermarket bulbs...
SW03ES
QUOTE (1990LS400 @ Aug 17 2009, 11:53 AM)
I guess so!
cduluk
Aug 17 2009, 01:14 PM
I've heard it time and time again over there, it's one of those things you 'pick up' after visiting every day. The members over there fight over 100's of lumens (which is very miniscule) between bulbs. They're indeed nuts about light.
I'm not saying you NEED to replace your HID bulbs (i can't think of one person who does besides HIDplanet fanatics) i'm just saying they lose considerable output over time, and that to get the maximum output, they need to be replaced often. After about 2000 hours HID bulbs are at 70% of their initial output. Starting at 3200 lumens, after 2,000 hours you're only putting out 2200 lumens. 1000 lumens is a LOT of brightness lost.
And yes, it differs between bulbs. Have you ever seen the early thousand's acura TL and RL headlights at night? Those bulbs are Osram, which start out the same output and color as philips, but over time they colorshift to a violet/pink color, whereas philips colorshift to a blue color. I'm pretty sure DOT wouldn't let a new car onto the road with that violet shade and lower output...
Seriously... i am not making this up.
EDITI opened a thread on HIDp asking for the graph and info i keep referring to (but couldn't find myself using their horrid search system) and here it is:
And here's a response from a respected member with over 8,000 posts.... "gearbox"
"guys you have to remember that most halogen bulbs keep 95% of their lumens just before burning out. the filament is always there and does not erode due to the halogen cycle, so the lumens are always there til the filament breaks.
hid on the other hand loses lumens like crazy, and after a certain time, it will negate the advantage of having hid lights. you need alot of lumens for the projector to work properly since so much of the light is spread out over a wide area. if you only have a 2000 lumen source instead of 3000, it will be much more dangerous to drive since the front of the car may not be lit up well enough. and sure hid can become dimmer than halogen, ive seen it all the time and have outshined many a car headlight with my civic halogen reflectors.
for comparison, i included a few landmarks along the way to compare to as the 85122 bulb ages. if it were me, i would change the bulbs every 1000 hrs to have the most output. and bulbs are cheap, i just got a brand new set of 85122 from ebay for $75 shipped. but you really need to add up your average night time driving. if you mostly drive during the day, then sure i could see you taking several years to reach 1000 hrs. some people will drive that much at night in 6 months who knows."Like i said, they don't NEED to be replaced (as they "
live" a long time) but their output suffers dramatically with age... You might think a 6yr old HID bulb is fine, but compared to a new bulb, you'll wonder how you saw a thing with the old one.
If you work a lot with HID bulbs and units, you'll know what a difference a few thousand hours makes...
SW03ES
Aug 18 2009, 09:54 PM
But your graph disproves what you were saying.
Here is what you said
QUOTE (cduluk)
And here is what you said after posting the graph
QUOTE (cduluk)
If their original output is 3200 llumens, 70% of that is 2240. According to your graph a new H1 Halogen bulb puts out 1800 llumens. So using your numbers, an HID bulb after
2,000 hours still puts out 640 llumens more than a halogen bulb...how does that prove what you said which was that after
1,000 hours HID bulbs put out the same as a halogen bulb?
If we use your numbers we'd estimate the HID bulb was still putting out 85% of its llumens after 1,000 hours, or 2720, 1000 more than the new halogen bulb...
cduluk
Aug 18 2009, 10:37 PM
QUOTE (SW03ES @ Aug 18 2009, 09:54 PM)
QUOTE (cduluk)
QUOTE (cduluk)
The 1,000hrs i was thinking of was the difference between a new 85122 and a new 85122WX, sorry hadn't seen that graph in quite a while.
Even still, it clearly shows the difference in output over time, which is considerable. After a few thousand hours, your not getting the same output the HID system was designed to work with, definitely not enough to pass SAE. Do/think whatever you'd like with your own bulbs, at this point i realize trying to share suggestions with you is a moot point- unless you've founded them. The evidence is there, you just choose to only see the "scraps" that seem to back up whatever you happen to believe.
I know bulbs, i know HID. Anyone with higher standards in lighting output, or anyone who's worked with them, knows the importance in keeping up with HID maintenance. Like i said before, unless you really care about light output, you won't see the point in changing bulbs every few years. I'm only sharing this suggestion because if you expect to maintain the output the headlight engineers designed your HID units to produce, you NEED to change your bulbs.
Sure, you can keep your HID bulbs in your car forever if you want. They'll "live" but you won't be getting the amount of light your headlights were designed to produce. Losing 1,000 lumens of light in an HID reflector is a LOT. It's like never replacing the cabin air filter in your car. Sure, your AC will still "work", but you'll be losing a lot of performance (which one probably won't even notice, since most people don't even know what a cabin air filter is)... It's called ignorance.
You asked why you need to change HID bulbs every few years, and i've explained why the best way i can. So do whatever you like! I'm only making a suggestion from experience in this field...
SW03ES
Aug 19 2009, 02:05 PM
QUOTE (cduluk @ Aug 19 2009, 12:37 AM)
I didn't post the data, you did! It very clearly doesn't support what you were saying. Of course output degrades over time, Jim and I weren't disagreeing with that but the statement that HID lights put out the same llumens as a standard halogen light after only 1,000 hours of use was what he and I both didn't believe...and now we see by the data you posted that it is not accurate.
QUOTE
You THINK you do. Thats the problem. You just proved yourself wrong man...we don't even need to try...
You obviously remembered wrong by your own admission:
QUOTE
If you are going to make a statement...be damn sure you're right. Double check your facts before you post them...thats what I do. If you are going to reference the graph...you might want to...I dunno...
look at the graph! I asked you to produce this graph and when you did...lo an behold...you were wrong.
Lets recap. This started with you saying that after 1,000 hours your HID lights only put out the same llumens as a halogen light. Now after I have pressed you we find out according to your own sources after 1,000 hours HID lights still put out 1,000 llumens more than a halogen light, and even after 2,000 hours they still put out more light than halogen...and I'm looking at "scraps" and being a jerk and not listening to any viewpoints that aren't my own.
So I should just let you post things that I know are inaccurate in incorrect?
The backpeddling is hilarious...first it was 1,000 hours, now its
QUOTE
First it was 1,000 hours...now its "a few thousand hours"...just admit when you have misstated instead of pretending that you haven't.
cduluk
Aug 19 2009, 06:02 PM
I don't care about my accuracy in the numbers. It wasn't the quantity i am arguing, it's the fact they lose a lot of the brightness over time. They need to be replaced every once and a while to maintain the maximum efficiency. I don't care about the specific numbers. Numbers are the data, i know the result. I don't make an effort to know numbers when i know the result. I stated the result, that they need to be replaced. You questioned the result, so i did my best to recall the data, which honestly doesn't make a difference since they both prove that you need to replace them.
My lord. I'm just gonna stop arguing, it's pointless. I'll just continue driving around with my new bulbs while all the rest of you people drive around with sub performing HID bulbs... All i'm trying to do is help!
SW03ES
Aug 19 2009, 07:38 PM
LOL! Right...the specific numbers only matter if they agree with what you are saying. When they no longer agree...the numbers don't matter. You're the one who referenced llumens and comparing them to halogen bulbs and you were happy to do that when you felt those comparisons would back up what you were saying, but now that they don't somehow I'm the one bringing numbers into the equation? You posted the numbers, not me! Do you read what you type? You should be a politician...
QUOTE
Actually it was your assertion that HID lights put out the same llumens as a halogen bulb after only 1,000 hours that made me question the result in the first place...and you yourself have proved to us that was incorrect...so I guess I was right to question the result since the result was wrong.
Just because the effectiveness of something degrades over time doesn't mean it "must be replaced". Using your logic we should replace struts at 30k miles, replace tires when they reach half their treadlife, do a 4 wheel alignment at every oil change, replace wiper blades every month, replace the battery once a year...because the effectiveness of these things degrades over time too.
Everything works better when its new...nobody is debating that. You however are telling people that they should spend their hard earned money to replace things before they need to be replaced. Just because something doesn't operate AS WELL as it did when new doesn't mean it must be replaced.
We've established that HID lights are still putting out over 50% more llumens than halogen lights at 1,000 hours (120k miles or so) and 25% more light than halogen after 2,000 hours (approximately 240k miles or so)...and you assert they "need to be replaced"? They don't need to be replaced, they would operate better certainly if they were replaced, but they operate just fine and safely as they are.
If you've got gobs of discretionary money lying around...and don't care about needlessly discarding bulbs filled with very environmentally destructive chemicals...then feel free to replace them every couple years so that you always have "optimum lighting". Don't however try to say they "need to be replaced" because you are wrong.
denslexusgx470
Aug 19 2009, 10:09 PM
Hey SW do you want to do the chemistry formulas for me for my organic chemistry class? lol.
SW03ES
Aug 19 2009, 10:35 PM
Do you want to pass? LOL
denslexusgx470
Aug 19 2009, 10:55 PM
QUOTE (SW03ES @ Aug 19 2009, 09:35 PM)
Hehe.. Of course I do!
I just barely read this thread, and just going through the math explanations gave me a headache.. which is the similar headache I get when I take a precal test or any chemistry test with mind-twisting math formulas ughh
SW03ES
Aug 19 2009, 11:16 PM
Imagine the headache of being involved in this thread...
denslexusgx470
Aug 19 2009, 11:24 PM
QUOTE (SW03ES @ Aug 19 2009, 10:16 PM)
that's why I didn't analyze everything discussed in this thread because I wasn't up to date when this thread first started lol. Besides, I just started organic chemistry in school now, and doing the prelabs and stuffs for this class is like 100x harder and more work than the inorganic chemistry class I took last year! ughhh...
I have a headache right now as we speak while I'm trying to figure out how to do this prelab hehe
president
Aug 20 2009, 10:15 PM
I am about to buy news D4S 8000k Xenon Headlight and 8000K 9006 HID Conversion Kit fog light to replace my stock on lexus GS 450h
I heard that there are some car maker ( European car )will show an on Board Computer Error on the dashboard when you install all the bulb that difference Wattage.
Have any one in the club happen to come across this problem?
I really need advise on this issue!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thank you
blake918
Aug 20 2009, 10:21 PM
QUOTE (SW03ES @ Aug 20 2009, 12:16 AM)
I read this earlier, and it's still hilarious now! ROFLMAO
denslexusgx470
Aug 21 2009, 12:50 AM
QUOTE (president @ Aug 20 2009, 09:15 PM)
Thank you
I'm not really sure with your GS450H but generally with the Japanese cars you can change the bulbs without any error messages. I don't think you should run into any problems changing the bulbs on your GS450H. Just make sure it's the right size and you should be fine
Only the German cars are picky like that. I know that with a BMW or Mercedes just to change the plate light bulbs to LED will instantly flash an error message on your info screen
I see a lot of threads on the BMW forums where people have to add special modules or whatnots to avoid encountering the error messages
president
Aug 21 2009, 02:50 PM
QUOTE (denslexusgx470 @ Aug 21 2009, 01:50 AM)
Thank you
Thank you for your advise
r0k0
Sep 6 2009, 09:10 AM
QUOTE (cduluk @ Aug 16 2009, 09:06 PM)
i've done 3 HID Projector retrofits in cars, lots of HID's in normal reflector and i've always used SharpHID.com Apexcone HID's... i've got a Set in my Lexus.. which was in my old Bimmer and in my Volvo... my HID bulbs and Ballast at 55W kit and they've been used for over 5 years.. Same as the kit for my old Cobalt, oncle's Cobalt, uncle's Friend WRX same kit but 35W for 3 years.. and they are still very very well brighter than any halogen or ebay junk hids
cduluk
Sep 6 2009, 05:20 PM
HID bulbs being run at 55W for 5 years? Oh boy, that's definitely one way to shorten your bulbs lifespan even more...
Unless they're philips DL50 or "maybe" the philips 35W 85122, i wouldn't bank on a long lifespan under 55W. Aftermarket HID bulbs can hardly survive on 35W for more than a couple of years...
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
