brettg
Jul 29 2009, 02:44 PM
Dear Friends,
My drivers side seat warmers seems to be always on. It is really annoying. Does anyone have any suggestions? Should I take apart the console and look if there are any bad connections? Should I check the fuses and/or battery connection? I am baffled. It would be a shame if I had to bring my car into the stealership if it was something really simple..
aquanuke
Jul 30 2009, 08:44 AM
Is the light out, and do you rotate the switch till it clicks, does it click?
if it was fuse etc I dont think it would work at all, so check the switch first.
brettg
Jul 31 2009, 01:20 PM
Yeah, the light still works and the knob does click off and on and appears to be funcitoning fine. I am battled...
DaveinTX
Jul 31 2009, 01:35 PM
the switch shoud be opening the circuit turning the heater off when it clicks, the switch must be bad.
brettg
Aug 1 2009, 06:53 AM
I agree the switch must be bad. I took apart the seat warmer assembly, just under the gear shift and above the center console, and it appears to work fine.
There is an electrical plug that I am going to disconnect to test whether it is in fact the switch causing the malfunction. I think I could probably find the part online and connect it myself, if all esle fails.
However, first I was thinking that I would dissconnect and reconnect the battery, since dissconnecting the battery resets some electrical functions, I think?
Any other ideas? Thanks in advance, Brett
aquanuke
Aug 1 2009, 08:28 AM
If the passanger seat works fine can you not switch the switches to determin if its just the drivers switch.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
