this is a 35Watt hid 5000k kit ($60) for the kit, everything came with the kit,
(i.e. all the cables, adapter cables, ballast, bulb, heavy duty double sided tape
and zip ties)
I originally plan on pulling the bumper out just a tad but found out that I have to pull the front bumper out almost half way out, I used a jack stands with a tower to support the bumper, also had 2 other towers on the end of each side of the bumper so when i pull the bumper, i'm not scratching the fenders
To remove front bumper, remove the 5 tabs bumper cover once you pop the hood
You also need to remove 2 bolts one of each end of the bumper behind the wheel well, 2 allen nut on the bottom half of the bumper and 2 bottom screw
at the bottom of the bumper where the mud guard is
Once you loosen up all 6 bolts/nuts gentle pull the bumper out half way
make sure you have the towers on each end of the bumper and on the jack stand. Use the jack stand to support the bumper so it won't accidentally fall on the ground scratching your bumper or damaging the projector fog light.
You will see on each side there is a flat service available to mount the ballasts, use alcohol wipes to clean area and make sure it's clean so the heavy duty double sided tape can adhere properly.
passenger side mount
Driver side mount
Remove existing H11 bulbs, disconnect wire
install Hid H11 bulb onto projectors
connect all the cables as per instructions came with kit
clean the ballast surface with alcohol wipes before adding the double sided tape on.
mount the ballasts as seen on picture above.
test fog lights before putting the front bumper back
use zip ties for cable management as needed
reinstall bumper in reverse instructions
Finish product
I also end up installing the Thundercloud grille and led side mirrors today too.
So far
Stage 1: Installed PIAA H11 Extreme white bulbs - slight improvement over stock
Stage 2: Installed 35Watt HID H11 conversion kit, - improve visibility, a good sign
Stage 3: Install a TSX Bi-xeon projector with full 55Watt OEM kit....pending on budget
Stage 4: Install super-charged ballasts instead of OEM ballast for improve lighting.....need to wait for Stage
3 to complete before proceeding to Stage 4
