Help - Search - Members - Calendar
Full Version: Rear Brake Rub - Rotor Groove
Lexus Owners Club (USA & Canada) > Lexus Owners Club > Lexus IS250 / Lexus IS300 / Lexus IS350 Forums > 01 - 05 Lexus IS300
jwande
I have an '02 IS300 with 62k miles. Within the last couple of months, when you turned to the right, you heard this awful grinding noise on the left rear. It sounded just like metal on metal, which it was. The groove in the rear rotor was grinding against the backplate at the 6 o'clock position. I ground away the backplate and that made it better. I had to grind more material away (1/8" deep total) from the 4-8 o'clock position. It now has stopped.
Tell me what is going out and why! I have changed the rear differential fluid, but went back with the factory callout from the manual. No issues like gear clanging or chattering. The right side shows a little history of the condition (rusted scraping in groove) but nothing recent. Do these axles float? Is there a pin in the axle shaft that may have dropped and it allowing my axles to shift side to side? dry.gif
smooth1
Can you take pics and post them so I can see what your talking about? Have you checked all your bushings and sway bar?
jwande
QUOTE (smooth1 @ Jul 20 2009, 07:18 AM) *
I haven't checked the rear bushings and sway bar. I don't understand why these going out would cause the rotor to rub. The rotor is bolted to the rear backing plate via the lug nuts?
smooth1
QUOTE (jwande @ Jul 27 2009, 07:03 PM) *
Ok, in the first picture, the disc is locked in place by the rotor and the lug nuts. There should be no rubbing issues. IF there are, then I think you were driving around with your lug nuts loose and it moved around. So long as the disc and rotor aren't structurally damaged it should be ok. You might want to check your lugs and stems to make sure they are properly holding also.
jwande
I can promise you the lugs were not loose. As far as the bushings and sway bar, they appear normal. No cracking, chunking, or shiny metal where the bushing has moved.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
