Help - Search - Members - Calendar
Full Version: Fs: Ls400 Parts 1990-1994 - Parting Out Car
Lexus Owners Club (USA & Canada) > General Lexus Forums > Buy & Sell Forums
dbullen
Have the following items remaining:
Keep in mind it's a 91 LS400 w/traction (Black Exterior, Gray Interior)
Still have the following items remaining:
Shipping will be added to all prices, PM me your ZIP and I'll price up shipping.
- All Relays ($10 each)
- Engine ECU $35.00
- ABS/Trac ECU $35.00
- Inside Fuse Panel ($20.00)
- Passengers front outside door handle, Both rear outside door handles
$30.00 per Handle
- Ashtray w/heated seats & Trac buttons ($20.00)
- Center Vents w hazard button ($15.00)
- RearView mirror (not faded both night/day view work great) $20.00
- Inside door handles (Have all 4 of them) $15.00 Per handle
- All 4 Door lock actuators ($10.00 Each)
- Trunk Lock Actuator($25.00)
- Horns ($15.00)
- Nakamichi Subwoofer ($30.00)
- Nakamichi Amp $30.00 (Fits 90,91,92 only)
- Passengers rear Window Motor & Regulator $40.00
- Drivers rear Window Motor & Regulator $40.00
- Dome Light ($15.00)
- Airbag ($35.00)
- Steering Wheel ($35.00)
- Wiper Arms ($20.00)
- Wiper motor ($30.00)
- washer resovoir & Pump ($30.00)
- Fuel Pump ($35.00)
- Fuel Tank w filler neck ($100)
- Power Mirror controls / Keyless Entry on/off switch $10.00
- Cruise Control actuator ($25.00)
- ABS Pump/actuator ($50.00)
- Steering rack (Needs one boot replaced) $50.00
- Passengers Inner Tail light ($20.00)
- Front seats (but they are worn, heater elements and all motors work good)
(Probably too expensive to ship, make me an offer on the motors/components)
- Sunroof Motor ($15.00)
- Front bumper Signal lights both side ($25.00)
- Steering Colum w/ignition + Drivers/Passengers/Trunk Locks and 1 Lexus Key that matches all locks ($100.00)
- Also have various interior trim pieces
- Have glass for all 4 doors ($25.00 each)
- Complete Front Visors Assembly ($35.00)
- 4 15" Alloy LS400 Rims (two with winter tires with lots of tread left)
Also willing to trade for the following: Climate control LCD or full unit with working LCD or Used Front O2 Sensor or Set of Front Rotors
glenmore
QUOTE (dbullen @ Jul 16 2009, 11:05 AM) *
Purchased a 91LS400 parts car, have removed the few parts that I need
(Cluster, MAF, Climate Control unit, CD Changer, Antenna, Drivers & Pass Window Switch, ))
Have pretty much everything else left except what I listed above. 1991 Black LS400 with Grey Interior.
How did the car idle? How much for IACV?
Thanks,
glenmore
1990 LS400
dbullen
QUOTE (glenmore @ Jul 16 2009, 10:33 AM) *
PM has been sent
Thanks,
glenmore
1990 LS400
skinsfan687
did the car have airbag suspension?
acflye
How much for the clock spring?
dbullen
QUOTE (acflye @ Jul 27 2009, 12:50 PM) *
PM Sent
dbullen
- All ECU's (Abs/trac, engine, Plus all the other ones)
- Two Front calipers w/pads (In excellent shape), they we put on within the last 6 months
- (outside door handles) - Passengers front door handle, Both rear door handles
- Inside door handles (Have all of them)
- Passengers front window switch, Both rear window Switches
- ClockSpring
- Wiper Arms
- Wiper motor
- Two rear mufflers
- Fuel Pump
- Fuel Tank
- Fuel Filler Neck
- abs Pump/actuator
- Airbag (drivers)
- Steering Wheel
- Steering rack
- Front Struts/Coils/Mounts
- trunk lid
- Inner Tail lights
- Sunroof Motor
- Steering Colum
Spinnetti
Hi, I need front and rear shock tops (or even the whole shock/spring asm) for standard steel suspension.. need soon if you have it. email me at dspinnett @ insightbb &&dot&& com
killerFatty
do you still have the coolent overflow tank?
vyhanh
Hi,
Do you still have 'Two Front calipers w/pads (In excellent shape), they we put on within the last 6 months'
How much for them? Do they include: Calipers, Pads, Pistons ?
Thanks
VH
QUOTE (dbullen @ Aug 8 2009, 01:07 AM) *
- ClockSpring
- Wiper Arms
- Wiper motor
- Two rear mufflers
- Fuel Pump
- Fuel Tank
- Fuel Filler Neck
- abs Pump/actuator
- Airbag (drivers)
- Steering Wheel
- Steering rack
- trunk lid
- Inner Tail lights
- Sunroof Motor
- Steering Colum
dbullen
PM Sent, sorry for delay, didn't receive an email notification that a new post was added.
QUOTE (vyhanh @ Sep 18 2009, 02:41 PM) *
Hi,
Thanks
VH
- ClockSpring
- Wiper Arms
- Wiper motor
- Two rear mufflers
- Fuel Pump
- Fuel Tank
- Fuel Filler Neck
- abs Pump/actuator
- Airbag (drivers)
- Steering Wheel
- Steering rack
- trunk lid
- Inner Tail lights
- Sunroof Motor
- Steering Colum
marlon08901
QUOTE (dbullen @ Sep 24 2009, 08:08 PM) *
Hi,
Thanks
VH
- ClockSpring
- Wiper Arms
- Wiper motor
- Two rear mufflers
- Fuel Pump
- Fuel Tank
- Fuel Filler Neck
- abs Pump/actuator
- Airbag (drivers)
- Steering Wheel
- Steering rack
- trunk lid
- Inner Tail lights
- Sunroof Motor
- Steering Colum
WHERE ARE YOU LOCATED??
TexFinn
Do you have front seat belts? If so, are they retracting properly, not frayed etc.?
dbullen
I have update the original post (See top of thread) with all parts I have left from this vehicle and prices for each. PM me with ZIP and item you want and I will give you a shipping price.
acflye
dbullen, you still have the clockspring.......i was going to get rid of my 93 but decided to keep it...
also, what about the seat belts (mine won't retract)
QUOTE (dbullen @ Oct 15 2009, 09:32 PM) *
dbullen
QUOTE (acflye @ Nov 10 2009, 05:22 AM) *
Sorry I just sold the clock spring about 2 days ago. I never ended up saving the seatbelts, sorry. If there is anything else you need just let me know.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
