There's an oil change DIY for an RX330 here
http://us.lexusownersclub.com/forums/index...showtopic=21979
but I think the underside of the 400h is a bit different (either that or I'm missing a really big splash shield - can someone confirm if the underside of their 400h looks the same as mine, please (i.e just the one splash shield that hides the oil filter, unlike the 330 which has two splash shields - one for the oil pan drain bolt and one for the filter). Thanks.
So, assuming my RX is not missing a splash shield, here's a quick DIY (note that I didn't actually drain the oil or remove the filter, as I had just done that recently but hadn't taken pictures)
1. Remove the underbody splash shield (there are eight 10mm bolts and two plastic clips)
Four bolts here - Click to view attachment
Two bolts and one plastic clip one the left and right side of the shield - driver side - Click to view attachment - passenger side - Click to view attachment
2. Remove oil pan drain bolt (here is where I 'think' we don't have a plastic shield and the RX330 does and let oil drain into drain pan (not the sewer or side of the road)
Click to view attachment Click to view attachment
3. Move drain pan to under filter and remove filter. If your pan is big enough, you can remove filter while the oil is still dribbling out of the oil pan
Notice those crafty Japanese engineers have added a drain channel thingamajig to direct the oil that will leak out when you remove the filter. This helps prevent oil from running all down the outside of the engine.
4. No pics for this next part as I had done the oil change before taking the pictures, but screw on a new oil filter (make sure you use a bit of fresh oil on your finger to lubricate the rubber gasket on the new filter. Also make sure that the old filter still has it's gasket on. If it's not, it's stuck to the oil filter mount on the engine and your new filter will leak.
5. Reinstall the drain pain plug (don't forget the gasket - I didn't replace mine, but I should have)
6. Refill with 5 quarts of your choice of oil. The oil fill hole is hard to reach with the inverter assembly in the way (the thing that has the fancy "Hybrid Synergy Drive" cover on it). Use a longish funnel and please note the following TSBs
-cylinder head oil baffle caution when adding oil - Click to view attachment
5w20 approved for 2006 (and onwards I would assume) engines (MZ included - this is the RX series engine - Click to view attachment
I currently have 5w30 synthetic in the engine but plan to switch to 5w20 synthetic in the summer and 0w20 synthetic in the winter. My current oil of preference is Pennzoil Platinum.
Miscellaneous - in case anyone was wondering this thing is the temperature sensor (to tell you the outside temp)
