Help - Search - Members - Calendar
Full Version: Comparable Air Filter Recommendations
Lexus Owners Club (USA & Canada) > Lexus Owners Club > Lexus ES250 / ES300 / ES330 / ES350 Forums > 07 - 09 ES350
pharmwriter
Instead of paying an extra $79 to have my air filter replaced for the first time I decided to do it myself (which is really easy, BTW).
Any recommendations for a comparable air filter that I can get from an auto parts store (versus over the internet)?
I could also get it from a Toyota dealer, right?
I have an '08. Thanks in advance.
cmasten
[quote name='pharmwriter' post='373934' date='Jun 1 2009, 08:54 PM']Instead of paying an extra $79 to have my air filter replaced for the first time I decided to do it myself (which is really easy, BTW).
I have an '08. Thanks in advance.[/quote]
I bought mine at Pep Boys, looked exactly like the factory one I took out.. for 12.00, they always have them in stock at my store here in So Cal so easy enough to get locally.. I only use the net if I buy in bulk
saabkyle04
[quote name='pharmwriter' post='373934' date='Jun 1 2009, 10:54 PM']Instead of paying an extra $79 to have my air filter replaced for the first time I decided to do it myself (which is really easy, BTW).
I'm also wanting to replace my air filter, my car has 26,000 miles and I didn't know it had to be changed every 15k :rolleyes: how easy is it to change out? What do you have to do to do it? I just called the dealer and like you said, it was about 70 dollars, I'd like to save that if I could haha, Thanks!!
pharmwriter
The air filter compartment is in the back of your glove box. All you need to do is remove the main filter door, then the secondary door, then pull out the filter. The instructions are toward the back of the manual, complete with illustrations. It's really simple. I figure the dealer charges $15 for the part and $64 for labor.
You were told 15K? I thought it was every 5K, or I guess whenever it needs to be done. I'm taking my car for my 10K service tomorrow, and I was quoted $151 by 3 dealerships, but only one dealer told me that it could be $230 if I need the air filter replaced.
Thanks for the tip Cmasten. Is there a brand of filter I should look out for at Pep Boys? Do you know if an aftermarket air filter void the warranty? I wouldn't think so, but you never know w/Lexus.
saabkyle04
Thanks a lot pharmwriter, I checked the owners manual and found it, I actually just went and took it apart to see  :cheers: but yeah I'm going to try to go to the local oriley's or something tomorrow and try and get a filter. Saved a bunch of money versus going to the dealer, idk why everything they do is so expensive!
Chuy
[quote name='pharmwriter' post='374489' date='Jun 5 2009, 12:58 PM']The air filter compartment is in the back of your glove box. All you need to do is remove the main filter door, then the secondary door, then pull out the filter. The instructions are toward the back of the manual, complete with illustrations. It's really simple. I figure the dealer charges $15 for the part and $64 for labor.
Thanks for the tip Cmasten. Is there a brand of filter I should look out for at Pep Boys? Do you know if an aftermarket air filter void the warranty? I wouldn't think so, but you never know w/Lexus.[/quote]
Technically, that's the cabin air filter you're describing. The air filter is in the engine compartment. I just bought a pair from RockAuto.com. But, only 'cause I was restocking my garage with parts for my wife's es350 and my Tacoma - oil filters, cabin filters, air filters and surpentine belts. Otherwise, Pep Boys, or even Wallyworld filters will do.
JoeCompute
I have used a Fram filter in my other Lexus, and oddly, the Fram is made in China while the OEM Nippon Denso is made in USA. The Fram was a good fit, but slightly different edge construction.
ronnand
I have used getcoolparts.com and found it to be cheap.
[url="http://www.getcoolparts.com/ShopByVehicle.epc?q=2007-LEXUS-Es350--/--V6--3456cc--3.5l--Gas--Fi--grfe-Filters&yearid=2007%40%402007&makeid=LEXUS%40%40LEXUS%40%40X&engineid=1433556%40%40ES350++%2F+V6-3456cc+3.5L+GAS+FI++(2GRFE)%40%40ES350&catid=Filters%40%40Filters&subcatid=Fresh+Air+Filter@@Fresh+Air+Filter&mode=PA"]http://www.getcoolparts.com/ShopByVehicle....ter&mode=PA[/url]
Went to the dealer and compared it to the one I got. exactly the same.
joeb427
[url="http://www.logical-source.com/productinfo.asp?year=2007&make=LEXUS&model=ES-SERIES&id=4153"]http://www.logical-source.com/productinfo....IES&id=4153[/url]
$6.97
Buy 2-3 and the shipping charge isn't as bad.
bearone
[quote name='joeb427' post='391823' date='Nov 3 2009, 04:51 PM'][url="http://www.logical-source.com/productinfo.asp?year=2007&make=LEXUS&model=ES-SERIES&id=4153"]http://www.logical-source.com/productinfo....IES&id=4153[/url]
$6.97
Buy 2-3 and the shipping charge isn't as bad.[/quote]
bearone
[quote name='bearone' post='392513' date='Nov 9 2009, 06:22 PM'][quote name='joeb427' post='391823' date='Nov 3 2009, 04:51 PM'][url="http://www.logical-source.com/productinfo.asp?year=2007&make=LEXUS&model=ES-SERIES&id=4153"]http://www.logical-source.com/productinfo....IES&id=4153[/url]
$6.97
[/quote]
I just replaced my cabin filter and engin air filter I bought both from Rock Auto for 24.39 including shipping.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2010 Invision Power Services, Inc.
