Help - Search - Members - Calendar
Full Version: How To Check For Vacume Leaks ?
Lexus Owners Club (USA & Canada) > General Lexus Forums > Lexus Modifications Forums
TroyLexus
Can anyone give me the rundown of how to check your vacume lines for air leaks ?? thatnks
jerzynuts
One way to check for vacuum leaks is to spray engine start, or some combustable spray, near all the vacuum lines while the engine is running. If you get to a spot where the idle increases, that's where the leak is. The leak will suck in the fumes from the combustable spray and cause the engine speed to increase like you pressed the gas pedal. But, be careful not to blow yourself up!!!! This can be dangerous. Especially with a hot engine. I did it from a cold start where the idling seems to be hitting hard the most.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
