QUOTE (commack4 @ Apr 9 2009, 06:51 PM)
One is in the glove box and two under the hood.....the glove box one is not the same as the under hood units.
The air filter in the trunk is only available in the LWB version equipped with separate a/c in the back. The other one is in the glove compartment and two under the hood. Once you replace the filters, simply press the AC OFF button while pushing the ignition switch with your foot off the brake to reset the AC reminder. Make sure you hold the AC OFF button for at least 4 seconds and the system will reset the reminder.
