QUOTE (abz-pete @ Oct 28 2009, 08:23 PM)
I've just had my snow tires put on at my local garage and the alarm went off after 25 minutes of driving - does this mean that a change of tires HAS to be done at a dealership?
Thanks.
QUOTE (paradigm @ Apr 8 2009, 10:14 PM)
reporting back in...
eventually the system figured it out and now alarms constantly. lol
due to the weather and my short commute to work, it took a while before i drove the car long enough to get the system to report the sensor mismatch.
i purchased toyota/lexus TPMS...still haven't had them programmed. i will ask them to do it when i take the car in for the fuel line recall.
I'm gettin snowtires too. I talked to Lexus service/parts they said if I only change the tire and keep the rims/tpm the same then all I have to do is take it to Lexus and they will reprogram the TPM to match snowtire PSI for free.
If you change both tires and rims (without TPM) then you're going to get the "tire pressure" alert, where you have to take it in to Lexus for them to reprogram it still.
