Help - Search - Members - Calendar
Full Version: Tire Size For 06 Gs 430
Lexus Owners Club (USA & Canada) > General Lexus Forums > Wheels and Tires Forums
mick6
Hi Guys,
Replacing my run flats size 240/45/18 can i use non run flats size 245/45/18? I also have inside wear that I never saw untill the car was up in the air any info on this problem with this car?
Thanks
steviej
the abnormal wear is a common complaint on the GS430, as far as I have read it is an alignment issue that sounds like it is hard to resolve on the 430.
Check you tire sizes again, the OEM runflat size was 245/40-18. Secondly, I don't think 240 is a valid width for a tire. They usually come in increments of 10 starting at 185 (195, 205, 215, 215, 225, 234, 245, etc.)
Lastly you most definately can use non-runflats. I dumped mine this past year.
steviej
mick6
QUOTE (steviej @ Feb 28 2009, 11:46 PM) *
steviej
thanks StevieJ.....would going from 40 to 45 work?
Thanks
steviej
QUOTE (mick6 @ Mar 3 2009, 04:15 PM) *
Thanks
Not suggested. If you put on a 245/45-18 tire instead of the stock 245/40-18, the car will travel 3.7% faster than what is displayed on the speedo. Most tire shops won't mount a set up that changes the speedo more than 2%.
steviej
Dark Lord
QUOTE (steviej @ Mar 3 2009, 10:35 PM) *
Thanks
steviej
I did mount mine at Discount Tire today..170 bucks for mounting, spin balancing, tpms rebuild....yuck...replace the 245/40/18 with 245/45/18...In deed, they seem to move faster smile.gif The guy at the shop said that I shouldn't have any problem with the tires except I might experience premature/abnormal wear ...hmm..any body see any negative side effects of using these tires?
Thanks
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
