QUOTE (eugene.s @ Dec 23 2008, 09:37 PM)
Hello All,
I bought a GX470 2005 in Russia and there are no Lexus centers in my region. The temperature here is around 14 F but the low tire pressure indicator flashs all the time (though the pressure in all 5 wheels is per the manual). I searched in this forum and in the web but failed to find some practical advice on the following:
1. Tips for checking the sensors by yourself. Where are they located?
2. Tips how to change tires on wheels (i.e. remove old tires and put new ones on the same wheel) -- how to do it not to damage the sensors; how to put the same sensors on new tires?
I would appreciate any practical advice.
Thanks
Eugene
The sensors are inside of the tires and part of each valve stem so are attached to the rim. Sometimes eBay has them for sale so you can see what they look like.
Changing rubber on the rims should not be a problem if a tire dealer does it and knows about the sensors. If you do it, be careful with the tire iron around the valve stem area. Changing out the sensors is a matter of removing the valve stem and reinstalling with new gaskets - they are a bit expensive however. Then a dealer has to electronically link the new sensors to your vehicle.
There is a reset switch for the tire pressure sensors under the dash. You'll have to search this site to find a post about it and how to specifically reset it.
Lexus tends to recommend low tire pressues so you might put an extra 3 or 4 pounds (whatever that is in metric) and see if the dash light goes off. Remember to do the spare.
