QUOTE (-the.k.w.c- @ Mar 22 2009, 03:13 PM)
air runner and ksport make bolt on kits for air bags .......you wont go hydro ...its way to ruff and your not going to be jumping the car not to mention you will need like 12 more batteries to power everything ...air is the way to go easy bolt on soft or hard ride and its clean, by this i mean if a line breaks you wont leak oil all over your car. coil over would be my 2nd choice
just to clear up the hydro vs airbag debate. (I have been a minitruck builder for years and have dealt with both setups, with several trucks published) Hydros DO NOT need 12 Batteries. They can easily be ran on 2 or 3 at the most for smaller applications. (still a lot for a car though) They do ride rough if not done properly. There are acummulators you can buy that soften the ride. (I am in no way telling you that Hydros are better for the application that you are looking for cause they are not, I just simply want to clarify) Bags are gonna be a lot softer ride. With new technology they can be just as fast and effective as Hydros. Still need Compressors and such so your gonna need mounting room. VIP is like previously posted gonna be the Coilover setups. They do make these with bags now. (little more expensive and will cost a little more for maintenance).
