Help - Search - Members - Calendar
Full Version: Gx470 Transmission Fluid
Lexus Owners Club (USA & Canada) > Lexus Owners Club > Lexus GX470 Forums
mann777
Could somebody tell me if at all anybody used non standard ( Mobil/Penzoil) ATF fluids has been ever used on GX model from Non dealers
if so your suggestion the brand, I had gone to the dealer and he suggest All toyota & lexus engines
should mandatory used the Transmission Fluid Type IV sold by the dealers in order for the transmission
warranty, Is it true, your advise !!!!
brickauto
QUOTE (mann777 @ Oct 30 2008, 11:03 AM) *
If your GX does not have a tranny dipstick then it is a "WS" ATF which leaves you with the safe choice of using original Toyota WS ATF only.
The 2003s uses the old T-IV which some aftermarket ATFs are compatible. I personally have Amsoil ATF in my 2003 (with tranny dipstick), I believe Valvoline Maxlife ATF is T-IV compatible too.
jdphomepro@hotmail.com
I have 30,000 miles on Royal Purple Multi Spec. Automatic Transmission Fluid without any problems. I am about to do a fluid change again. Please note you need a scan tool to read ATF temperature for correct fluid level check. I can send you the manual you could follow if you need it. I use their products for every fluid my vechicle requires.
I order it from here. Stock up on all fluids at once since they charge $9.00 fee on all orders.
http://www.jegs.com/i/Royal+Purple/831/01320/10002/-1
You can call Royal Purple technical support at phone: 281-354-8600 with any questions.
mann777
Hi could you email a soft copy of the manual to my email address. mann68'2gmail.com... appreicate your support.
thks - mann
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
