QUOTE (jayhawk793 @ Oct 29 2008, 12:53 PM)
Thanks for the input Steve, the wheels I used can be found at the link below and I used the Bridgestone Blizzak tires LM25.
http://www.tirerack.com/wheels/WheelCloseU...=Silver+PaintedWill the change in wheel size mess up the mileage as well? I talked to the Lexus Service dept the other day and they said it would not change this as the tire is a little larger on a 17' wheel do the difference is minimal.
Regarding the sensors I need to get them programmed into the car so I will need to take it in. I wish there as some way to do it myself. It seems like it is a really easy task but who knows, right?
Thanks again,
Anthony
Anthony, it is not so much the change in wheel size that messes mileage up as it is the tire mounted on the different size rim.
There are many different size tires that fit on the same 17" rim. you need to list what size Blizzak tire you mounted.
But let's assume the tires for the 17" rims are 225/45-17 in the front and 245/45-17 in the rear
and your tires for the 18" rims are 225/40-18 in the front and 255/40-18 in the rear.
This swap from the 18" tires to the 17" tires would result in a 0.5% difference on the front and 1.3% difference on the rear. Anything less than 2% is acceptable.
Call around to Toyota dealerships, they will program the sensors in for less provided you have the codes. If you are buying them from TireRack, they provide you the codes. Usually they are on the side of the sensor, but once mounted in the tire, you can't see them.
steviej
If your stock 18" size of
